raff e30 Posted March 16, 2012 Share Posted March 16, 2012 my 97 auto box legacy just got the engine rebuilt, the engine is back in, when i drive and put the foot to the ground,its like the car is confused first it does nothing then it changes down,pulls a little changes again then when it reaches about 3000 rpm it pulls away ok, but it feels like only the front wheels are getting power,and very unevenly. the steering wheel pulls to one side and then to the next,like if there was bad traction how do i know if my torque converter is working properly tanx for the help Link to comment Share on other sites More sharing options...
outbackjack Posted March 17, 2012 Share Posted March 17, 2012 look at the tranny pan cause I was having similar probs after buying my buddies car. He had motor swapped out by one of his technicians. They put the jack stand under the pan and pushed up the pan. I pulled it down and pushed dent out and it shifts and runs fine now. Do you have a ck engine light? if so what are the codes? TPS? Link to comment Share on other sites More sharing options...
raff e30 Posted March 17, 2012 Author Share Posted March 17, 2012 ill have a look at the pan 2 morrow. no light on,not shure if i have one. where would it be?? Link to comment Share on other sites More sharing options...
outbackjack Posted March 18, 2012 Share Posted March 18, 2012 The check engine light is right in front of you while driving, its in the instrument cluster in the middle of the gauges. If you dont see one on confirm the check engine light is working by turning the key to the on position (dont start car). the light will be on as many others as well like airbag and whaterver. If you have a check engine light on while driving it take it to advanceautoparts or some place like that and have them pull the codes. Link to comment Share on other sites More sharing options...
raff e30 Posted March 18, 2012 Author Share Posted March 18, 2012 dont have one!! bulb dead??? no light comes on only the normal ones like air bag,handbrake ect Link to comment Share on other sites More sharing options...
outbackjack Posted March 19, 2012 Share Posted March 19, 2012 dont have one!! bulb dead??? no light comes on only the normal ones like air bag,handbrake ect ok so just take it to an auto parts place and get the codes read this will give you an idea as to what is wrong. The bulb doesnt have to work for the codes to be read. Then report back what codes numbers they read. Link to comment Share on other sites More sharing options...
