Silver Bullet Posted July 4, 2005 Share Posted July 4, 2005 Ok here is a questions that I'm hoping some of you can answer for me. A buddy of mine owns a 2004 WRX and has a blow out valve currently on the car that he said he will GIVE to me because he is looking to get a new one. My questions is this...will it fit?....is the configuration the same on a 2004 WRX as a 2005 LGT Limited so I can install blow out valve with no problems? If anyone can answer that please let me know...i would love to throw one of those things in there. In addition, does anybody have a set of 2005 Legacy GT factory rims they are looking to get rid of???? The same friend of mine who is giving me the blow out valve wants to put the 17" Legacy rims on his WRX. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 4, 2005 Share Posted July 4, 2005 no it wont bolt on...you can make a custon flange for it tho or drill directly onto the base of it to make it fit...and its a blow 'off' valve...hehe Link to comment Share on other sites More sharing options...
Brady Posted July 4, 2005 Share Posted July 4, 2005 a blow out would be bad on those rims. Link to comment Share on other sites More sharing options...
melayout Posted July 4, 2005 Share Posted July 4, 2005 A Blow Out valve releases pressure from tires when a sudden decrease in pressure is detected to avoid blow outs....huh ?!!!!! I keed I keeed Link to comment Share on other sites More sharing options...
Silver Bullet Posted July 4, 2005 Author Share Posted July 4, 2005 no it wont bolt on...you can make a custon flange for it tho or drill directly onto the base of it to make it fit...and its a blow 'off' valve...hehe So if i drill right into the base of the turbo and make it fit will it still work properly? I'm a little hesitant to take my power drill and start making holes in my turbo. And yes, I'm sorry, it is a Blow Off Valve...what was I thinking? Link to comment Share on other sites More sharing options...
melayout Posted July 4, 2005 Share Posted July 4, 2005 You should not be drilling holes into your turbo, unless I'm missing something. I keed I keeed Link to comment Share on other sites More sharing options...
franklin Posted July 4, 2005 Share Posted July 4, 2005 So if i drill right into the base of the turbo and make it fit will it still work properly? I'm a little hesitant to take my power drill and start making holes in my turbo. And yes, I'm sorry, it is a Blow Off Valve...what was I thinking? This is a a type of mod that most people are reluctant to do anyway but if you want to do this to a new car I strongly reccomend spending the money to get the proper equiptment. Link to comment Share on other sites More sharing options...
rc0032 Posted July 5, 2005 Share Posted July 5, 2005 So if i drill right into the base of the turbo and make it fit will it still work properly? I'm a little hesitant to take my power drill and start making holes in my turbo. And yes, I'm sorry, it is a Blow Off Valve...what was I thinking?The BOV doesn’t attach to the turbo, it attaches to the Inter Cooler which is plastic so DON’T drill into it. I would suggest you learn more about the car before you do serious damage. Link to comment Share on other sites More sharing options...
melayout Posted July 5, 2005 Share Posted July 5, 2005 The car comes with an Air By-Pass Valve stock. Like rclark0032 said, research and learn more about your car before touching anything. Check out the attached PDF to see where it is located.09 - Air By-Pass Valve.pdf09 - Air By-Pass Valve.pdf I keed I keeed Link to comment Share on other sites More sharing options...
NHLEG Posted July 5, 2005 Share Posted July 5, 2005 Silver Bullet - leave the stock BPV as is. Do not replace it. It is all that you will need unless you end up pushing 18+ lbs of boost. I won a BOV in a raffle and after ALOT of research realized that it would do NOTHING performance wise (just a "psssshhhhh" and a rich running car). I traded it for sway bars...A needed mod. Link to comment Share on other sites More sharing options...
Rommel Posted July 5, 2005 Share Posted July 5, 2005 BOV on a LGT = useless mod IMO no BOV on a LGT = total sleeper Link to comment Share on other sites More sharing options...
meier motor sports Posted July 5, 2005 Share Posted July 5, 2005 silver bullet... STEP AWAY FROM ANY TOOLS. CLOSE YOUR HOOD. WALK AWAY. FIND A PROFESIONAL! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 5, 2005 Share Posted July 5, 2005 hahahaha....base of the bov...not the turbo Link to comment Share on other sites More sharing options...
