.... Posted March 12, 2012 Share Posted March 12, 2012 edit Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 12, 2012 Share Posted March 12, 2012 Did he send you a map for your vf48? Did he suggest a 1mm restrictor pill or did you just find that on here? Just go ask him. It looks like you are running off wastegate boost. Link to comment Share on other sites More sharing options...
.... Posted March 12, 2012 Author Share Posted March 12, 2012 edit Link to comment Share on other sites More sharing options...
iNVAR Posted March 13, 2012 Share Posted March 13, 2012 ask infamous, he's your tuner. work with him. edit: WGDC is already pretty high. I don't like giving advice when you're in the middle of a tune, but perhaps you put the restrictor pill in the wrong place (again? since you said it was in the wrong line the first time....?) edit2: It sort of looks like the compressor is hooked up directly to your actuator.... Did you reconnect your solenoid? Link to comment Share on other sites More sharing options...
.... Posted March 13, 2012 Author Share Posted March 13, 2012 edit Link to comment Share on other sites More sharing options...
