OBD Parameter ID List
Metal2You
Does anyone have a list of OBD PID's for a 2006 LGT, or know where I can find them? Maybe Enginuity or some other software can list them out for me?
I want to do some data logging. I just got a bluetooth OBDII reader and the Torque Android app. It is working fine, but I need to program in some extended PID's for things like :
Knock Correction
Dynamic Advance
Dynamic Advance Multiplier
A/F Trim Current
A/F Trim Learned
WGDC
Thanks.
Um, are you suggesting I look at the XML file to get the HEX PID's?
Apparently RomRaider uses the SSM protocol. Torque uses OBD protocol. Is the Address value in the XML file the proper PID for the OBD protocol?
Can you give an example of how to parse the data form the XML file and input it into Torque?
I looked at a couple of default PID's in Torque (RPM, and Intake Air Temp) and compared them to the Address values (only HEX values I could find) in that ROMRaider XML file. Unfortunately they are different, so this isn't what I need.
Thanks for trying though.
