dylanwaible Posted March 8, 2012 Share Posted March 8, 2012 Got the 98 Legacy OB a few weeks ago from my brothers work for 2000. It had 234K on everything and supposedly it got a new head gasket and a couple other fixes at like 230K. One of the Subaru mechanics at my brothers work said it had a misfire code and the check engine light periodically came on. It idled low when it got warm (between 400 and 600 RPM) and the valves were ticking. Also made a rattling noise after it would shift. Did an oil change yesterday because the 5-30 is too thin. So today it ran fine and a lot more quiet then I pull into a parking lot stop and park and see smoke and smell oil burning then watching the low oil light come on. There had to have been two quarts on the pavement so i just put the extra quart i had in there and drove it a few blocks to park it at my brothers. I think the front main seal is blown.. I want a newer engine anyways.. What are my best options for $4,000-$5000 ?? http://i1161.photobucket.com/albums/q513/dwaible22/IMAG0172.jpg Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 8, 2012 Share Posted March 8, 2012 Check out the turbo FAQ sticky at the top of the second gen forum page. It lists a lot of engines, boths USDM and JDM. With $4-5k you can just about anything you want. You could buy a crashed WRX and swap the engine, ecu, etc., into your OB. There are tons of JDM engines w/transmissions on ebay. What is a front main seal? I know what a rear main seal is. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted March 8, 2012 Share Posted March 8, 2012 http://legacygt.com/forums/showthread.php/ma-ej255-ej257-short-block-needs-rebuild-181430.html?t=181430 Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 8, 2012 Share Posted March 8, 2012 ^Are you suggesting the block as an option, or showing us what a rear main seal looks like, lol. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted March 8, 2012 Share Posted March 8, 2012 A used block that he could use/ build Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 8, 2012 Share Posted March 8, 2012 Awesome block, great price. Link to comment Share on other sites More sharing options...
dylanwaible Posted March 12, 2012 Author Share Posted March 12, 2012 Got it checked out just to see what was wrong with it and turns out my internals are still fine after 235k miles but the cam seals, crank seal(front main seal), and water pump all needed to be replaced. The guy got that and a few small things done in two days and only for $630.00 Link to comment Share on other sites More sharing options...
