todd12345 Posted February 25, 2012 Share Posted February 25, 2012 Do they make an oil pressure gauge for the turbo?? Link to comment Share on other sites More sharing options...
PhilT Posted February 25, 2012 Share Posted February 25, 2012 The turbo oil is fed directly from the engine oil system, no separate gauge is needed. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
halwith Posted February 25, 2012 Share Posted February 25, 2012 you could probably T in a gauge on the feed line. you are concerned of the banjo bolt oil starving your turbo? Link to comment Share on other sites More sharing options...
todd12345 Posted February 25, 2012 Author Share Posted February 25, 2012 Ok. Because i 'm going on my 2nd new turbo. And i want to make sure it is getting even oil pressure. Link to comment Share on other sites More sharing options...
pikeys Posted February 27, 2012 Share Posted February 27, 2012 Tee-ing in at the turbo can get you pressure at the turbo. Pressure isn't the silver bullet, but it will tell you if you have starvation on the supply side. What were the failure modes of the previous turbos? Seals or bearings? Link to comment Share on other sites More sharing options...
bmx045 Posted February 27, 2012 Share Posted February 27, 2012 if you havent inspected the oil feed banjo filter right UNDER the turbo then you're not fixing the problem by replacing the turbo, the filter might be clogged causing limited oil flow to the turbo Link to comment Share on other sites More sharing options...
todd12345 Posted February 28, 2012 Author Share Posted February 28, 2012 I don't know about the first turbo. But the replaced the lines, banjo bolt, screen and the turbo. And that one lasted 3000 miles. Then the bearing went. Link to comment Share on other sites More sharing options...
