Al Thomson Posted February 19, 2012 Share Posted February 19, 2012 Just wanted to put this out there, possibly it already on here somewhere. I changed the plugs on my 2007 today and found that the air pump thing on the drivers side is totally in the way of getting the coil packs off. I found that if you remove the little cover to the front of the pump think then you can remove the three bolts holding it in position. Then you can unclip the formed hose/tube and the bolt holding the side piece. Thereafter access to the coil packs and plugs becomes much easier. Link to comment Share on other sites More sharing options...
