Heedz Posted February 13, 2012 Share Posted February 13, 2012 Has anyone been able to do this, don't see anything posted nor on ground control since we do not have a macpherson rear end. Link to comment Share on other sites More sharing options...
whitetiger Posted February 13, 2012 Share Posted February 13, 2012 may have to be a custom job. Link to comment Share on other sites More sharing options...
Heedz Posted February 13, 2012 Author Share Posted February 13, 2012 yeah at that point possibly a little more uncomfortable coilover set up would be cheaper.... UGH the fronts seem to be plain and simple. I would just do springs plus konis but without the less coil I wont be able to fit 255s or whatnot :/ Link to comment Share on other sites More sharing options...
AZP Installs Posted February 14, 2012 Share Posted February 14, 2012 Konis and pinks should get you there. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Heedz Posted February 14, 2012 Author Share Posted February 14, 2012 ^I want more clearance for tire. the front struts are too limiting and I do not want to have a mis matched set. Same goes for the rear. Link to comment Share on other sites More sharing options...
Heedz Posted February 14, 2012 Author Share Posted February 14, 2012 Konis and pinks should get you there. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" I'm sorry but I don't think you understood the point whatsoever http://fc02.deviantart.net/fs70/f/2010/194/6/b/Facepalm_ID_by_urkel8534.jpg Link to comment Share on other sites More sharing options...
AZP Installs Posted February 14, 2012 Share Posted February 14, 2012 ^I want more clearance for tire. the front struts are too limiting and I do not want to have a mis matched set. Same goes for the rear. I ran 255s on my 05 wagon with konis and pinks. I tracked my car no issue. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Heedz Posted February 14, 2012 Author Share Posted February 14, 2012 On a 35 series sidewall right? That's way too thin for a car that also gets dailyed Link to comment Share on other sites More sharing options...
AZP Installs Posted February 14, 2012 Share Posted February 14, 2012 On a 35 series sidewall right? That's way too thin for a car that also gets dailyed To be honest, i dont remember the height, however i dd it in nyc and nnj, so they couldnt have been that bad! Mike Link to comment Share on other sites More sharing options...
whitetiger Posted February 14, 2012 Share Posted February 14, 2012 On a 35 series sidewall right? That's way too thin for a car that also gets dailyed 35 is a percent of tread width, not an absolute dimension. 255/35/18 has essentially the same sidewall as a 225/40/18 which is probably one of the most common tire size for 18" there is and fine for daily driving in the tri-state area. Link to comment Share on other sites More sharing options...
Heedz Posted February 14, 2012 Author Share Posted February 14, 2012 35 is a percent of tread width, not an absolute dimension. 255/35/18 has essentially the same sidewall as a 225/40/18 which is probably one of the most common tire size for 18" there is and fine for daily driving in the tri-state area. I know its 35% of 255mm I live in crappy road california, I need a few more MMs of tire to not do what I just happened to live through, broken sways and bent rims. Never had an issue when I had 235/45 R17 which cleared by 1mm or so. Link to comment Share on other sites More sharing options...
AZP Installs Posted February 14, 2012 Share Posted February 14, 2012 I know its 35% of 255mm I live in crappy road california, I need a few more MMs of tire to not do what I just happened to live through, broken sways and bent rims. Never had an issue when I had 235/45 R17 which cleared by 1mm or so. Ok so since your roads are worse than the ones here in the NYC/NNJ then you will need a full on rally setup. KWs and most other coilovers meant for road racing will not be good for what you want to do with the car, or you will be rebuilding them every 10k miles. -mike Link to comment Share on other sites More sharing options...
Heedz Posted February 14, 2012 Author Share Posted February 14, 2012 Gravel set up exactly not tarmac Link to comment Share on other sites More sharing options...
Firepuma Posted February 15, 2012 Share Posted February 15, 2012 In theory you can do it. Locking collars, perches and springs. Did this in volvos- here's an old for sale add listing what you need- http://volvospeed.com/vs_forum/topic/148359-diy-coilovers-parts-everything-you-need-usd-18000/page__fromsearch__1 Link to comment Share on other sites More sharing options...
