severedevil Posted February 11, 2012 Share Posted February 11, 2012 sounds like a vacuum leak. too dark to really see. now i just got a new head because the cams were shot on the driver side. new belt, new plugs. now it drives fine and idles ok. but after about 15seconds of idle it starts to run rough. and there's a loud sucking sound coming out the air intake where the filter is. didn't sound normal but im not sure. its a 97 legacy gt. any input? Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted February 11, 2012 Share Posted February 11, 2012 Does it have a filter in it? Without one it will be loud like that Link to comment Share on other sites More sharing options...
severedevil Posted February 11, 2012 Author Share Posted February 11, 2012 yes it has a filter maybe its not on all the way but would not being on all the way cause a rough idle? Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted February 11, 2012 Share Posted February 11, 2012 I don't think so does it idle and die or just keep on giong? Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted February 11, 2012 Share Posted February 11, 2012 Have you checked to make sure your MALF is plugged in? Link to comment Share on other sites More sharing options...
severedevil Posted February 11, 2012 Author Share Posted February 11, 2012 yeah its plugged in. it idles real rough and drops from 700rpms to 4-500 rpms after about 10-15 secs and runs rough. Link to comment Share on other sites More sharing options...
johnegg Posted February 11, 2012 Share Posted February 11, 2012 there is a large 1"+ hose that attaches under the black plastic tubing that runs from the air filter box to the throttle body. impossible to see. it leads , eventually, to the PCV. Link to comment Share on other sites More sharing options...
