ASpall Posted February 10, 2012 Share Posted February 10, 2012 I have a Legacy 2005 3lt and a while ago the A/C just stopped blowing cold. I recently tried checking the gas (I am an A/C technician), after buying the required fittings for the car valves, and found the compressor was not operating. With the car idling, it still gave me 12psi SP. the discharge needle did not even rise. I pulled the fuse which turned off the entire A1 a/c control display and the evaporator fan motor inside. I replaced the fuse and adjusted the temp to hot and then to cold and realized there was no clicking from the control relay to start or stop the compressor from pumping. Question: Where is the relay for the A/C compressor located? Link to comment Share on other sites More sharing options...
