Shudder and front diff leak - seal replacement?
doctorbrody
While driving between Baltimore and Boston, I started to develop a strong vibration in the car when on the throttle. Vibration disappeared when I took my foot off the gas.
Once home I lifted the car and saw diff oil leaking from where the passenger side half-shaft meets the front differential. Dipstick level was just above L. Drained and refilled and found some tiny metal pieces in the remaining fluid. It drives a bit better now, but still definitely a problem. Amsoil 5EAT fluid looks good and trans is shifting fine, engine is running smooth.
The axle at the leak is a $75 EMPI which I installed a year (15k miles) ago. I have a spare axle on hand, since my CV boots go so often. I'm going to swap them out and see what that does. Fingers crossed.
Anyone know if there is a seal in the front diff that I can replace as well? Or is it more likely the leak is because the axle's splines or whatever are worn down?
  • 4 years later...
