luvmylegacy98 Posted February 6, 2012 Share Posted February 6, 2012 sooooo a while back, i slide my 98 legacy gt into a curb my mistake. knocked it waaayyy out of alignment. while fixing the exhaust leak that recently sprung up, i decided to take a look at the steering rack. need a new ball joint on the front right side, new inner tie rod end on the passenger side, and an alignment. i will take it somewhere to get a front alignment but will be replacing the tie rod end and ball joint myself. how do i replace the inner tie rod end? i know how to do the ball joint cause the other side went out about a month ago. also needs new rubber boots on the steering rack. the ones on there are ripped to shreds Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 6, 2012 Share Posted February 6, 2012 the inner one just screw into the rack ends. remove a boot and you will see. BNR18g on 93oct Link to comment Share on other sites More sharing options...
WESTcoast Posted February 6, 2012 Share Posted February 6, 2012 If you are looking up performance replacements try out the Whiteline Roll Center kit. It comes with upgraded ball joints and outer tie rods, just pick up some inner tie rods and you have a great performace mod and some heavy duty parts! here is a link to them http://www.whiteline.com.au/product_detail4.php?part_number=KCA313 Link to comment Share on other sites More sharing options...
