nismohrdbody Posted February 3, 2012 Share Posted February 3, 2012 hey guys, i have only had my lgt for about a month now. i had pulled the plugs cause i was gonna change them but oriellys did have the same plug or one that was comprable to it. and the plugs i pulled didnt look that bad so i put them back in, but i might have accidently gapped them to far, cause when i took them off i just thru them into my tool bag. so my question is do yall know what the gap distance is supposed to be? i was wanting to throw the ngk silfr6a plugs back in it? is that the best one to use? i wasnt sure so i was just gonna put back in what i took out. p.s. the reason i was checking was cause i have been babying the car, and i decided to "get on it" today, and it hesitates a in all gears at low rpm's but once it gets up to about 4 itll take off.? my buddy was saying his supra and wrx did the same thing and it was the plug gap..... ? thanks guys. Link to comment Share on other sites More sharing options...
GTTuner Posted February 3, 2012 Share Posted February 3, 2012 SILFR6A is all I recomend. What brand and part number did you get? All NGK plugs with a "-11" suffix denotes a wide gap plug. Those are not the correct plugs, NA engines only. SILFR6A's are pregapped at .032". Do not try and gap unless visual inspection reveals a closed gap. Link to comment Share on other sites More sharing options...
nismohrdbody Posted February 3, 2012 Author Share Posted February 3, 2012 ok cool thats what i was thinking. yeah the silfra6 is whats in there now Link to comment Share on other sites More sharing options...
