moawdtsi Posted February 3, 2012 Share Posted February 3, 2012 Hey all, I have a newbish question here. I have a SPT catback exhaust but am otherwise stock (including paper filter). My stock TMIC is leaky and I am considering a Perrin type TMIC as a replacement. Will I need a tune for this? My line of thinking is no since the ECU still knows how much air is coming in the intake via the MAF and boost is still being regulated on the wastegate via the EBC. My only concern is boost could possibly go higher due to a lower restriction/resistance from a larger volume of the thicker aftermarket TMIC. Still though, boost is being controlled by the EBC. Can anyone offer any insight? Thank you, -Tim Link to comment Share on other sites More sharing options...
Buzzman Posted February 3, 2012 Share Posted February 3, 2012 Are you getting an aftermarket down pipe as well? Link to comment Share on other sites More sharing options...
moawdtsi Posted February 3, 2012 Author Share Posted February 3, 2012 nope, for now its just the aftermarket TMIC to replace the stock leaker, otherwise stock with the exception of the SPT cat back Link to comment Share on other sites More sharing options...
compsurge Posted February 3, 2012 Share Posted February 3, 2012 You should be ok without a tune. If anything, you could tune it more aggressive on the timing since the charge temperature should be lower. I've been running 15k on a Cobb OTS stage 2 tune with an IPR TMIC. Link to comment Share on other sites More sharing options...
NSFW Posted February 3, 2012 Share Posted February 3, 2012 Yeah, I vote no tune as well. But, log a couple of pulls just to be sure. Link to comment Share on other sites More sharing options...
ragman Posted February 3, 2012 Share Posted February 3, 2012 Get a Downpipe to go along with an aftermarket TMIC and then a custom tune. If that isn't your plan, just pick up a cheap stock TMIC used replacement. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 3, 2012 Mega Users Share Posted February 3, 2012 i ran an FMIC for a few weeks with no tune. ran just fine. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 going to a better cooling device usually doesn't render increased knocking. if its a fmic sometimes tip-in needs to be adjusted and wgdc since it might take more wastegate to reach target boost. you should be fine without a tune Link to comment Share on other sites More sharing options...
iNVAR Posted February 7, 2012 Share Posted February 7, 2012 That's a rather expensive replacement without yielding much better performance. Maybe if you were stage 2. If you just want to keep your car running as it is now, just get a good working used TMIC. I sold mine a few years back here to another LGT member for dirt cheap. Something like $50 shipped. And save your money. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted February 7, 2012 Share Posted February 7, 2012 just do this http://legacygt.com/forums/showthread.php/bulletproof-tmic-mod-lgt-08-wrx-158870.html Link to comment Share on other sites More sharing options...
