sgt Posted June 28, 2005 Share Posted June 28, 2005 Does such a thing exist? If so, can anyone recommend one? I have looked around here and elsewhere with no luck, seems all the FM mods have RCA input. Link to comment Share on other sites More sharing options...
drewster Posted June 28, 2005 Share Posted June 28, 2005 what's the source that you want to play thru the radio that only has speaker level outputs and not RCA outputs? Link to comment Share on other sites More sharing options...
sgt Posted June 29, 2005 Author Share Posted June 29, 2005 I want to run the output from the stock head into my alpine, but without spending big bucks for an iLink box I have no aux input otherwise. I just feel bad having that stock head unit being dead weight. Link to comment Share on other sites More sharing options...
drewster Posted June 29, 2005 Share Posted June 29, 2005 if i'm understanding what you want to do is to connect the oem radio output into auxiliary input of your alpine headunit, i think you can connect the speaker level outputs with a LineOutConverter to an Alpine AiNet/RCA connecter. Not sure why you would want or need a fm modulator? Here's a shot of an AiNet/RCA cable. http://akamaipix.crutchfield.com/products/2003/469/h469ALPAiRC-f.jpeg Link to comment Share on other sites More sharing options...
sgt Posted June 29, 2005 Author Share Posted June 29, 2005 Because I also have an EQ and changer taking up the ainet connector. The only way to use that adapter is to get the iLink box which is like $3-400. Link to comment Share on other sites More sharing options...
