RedDawg Posted January 28, 2012 Share Posted January 28, 2012 Last weekend my Hella Supertones stopped working. I pulled them off today, noticed the switch i got from Subimods was pretty well corroded, i guess i didnt wrap it with enough electrical tape. So i went and bought a new switch from Pepboys, rewired it up, and they still don't work, all i hear is the 1 remaining oem horn that's plugged in. I have it wired up like this: http://i41.tinypic.com/23h66he.jpg that's how they were wired up when they did work, i tried switching the pins around, still nothing. I can hear the switch "activate" when i plug the 15A fuse (i mislabeled it as 16A on the pic) into the inline fuse case, but the horns still dont work. anyone have any ideas? Link to comment Share on other sites More sharing options...
RedDawg Posted January 30, 2012 Author Share Posted January 30, 2012 still couldnt get them to work after fiddling with it for a few hours sunday so i pulled the entire wiring harness out of the car and plugged back in the oem horns. I should be able to "test" the hellas by directly wiring them to the battery right? If so, then i think the horns themselves might be shot because i ran the 16A fused wire, and a ground wire, directly off the horns and touched them to the corresponding battery terminals, and nothing, no sound. Link to comment Share on other sites More sharing options...
Windy Road Posted January 30, 2012 Share Posted January 30, 2012 Correct if you put the horns straight to the battery they should work. My first set of hella stopped working on me. But for some reason they worked again so I now have 4 hella's on my car. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
sschmelcke Posted January 31, 2012 Share Posted January 31, 2012 Check the fuse for the stock horns. I had the same issue. Turns out I popped that somehow. Link to comment Share on other sites More sharing options...
proflatlander15 Posted January 31, 2012 Share Posted January 31, 2012 I kept popping stock fuses. I think it's 15A. I threw a 20A fuse in there and haven't had a problem. Link to comment Share on other sites More sharing options...
RedDawg Posted January 31, 2012 Author Share Posted January 31, 2012 Check the fuse for the stock horns. I had the same issue. Turns out I popped that somehow. i replugged in the oem ones and they work fine. so its either something got burned out inside the wiring harness, or the hellas themselves are fried. prob have to wait until the weekend to have time to toy around with them again. Link to comment Share on other sites More sharing options...
