quick4dr Posted January 27, 2012 Share Posted January 27, 2012 just got me new eclipse 16-pin harness in to soon mount up my eclipse single DIN in new JDM dash. Basic question: do i just solder up each corresponding wire in the harness? To attach the red and orange to the already made connection whats the best recommended method? just strip a portion and attach the leads in? Link to comment Share on other sites More sharing options...
mr.hicksta Posted January 27, 2012 Share Posted January 27, 2012 Soldering will give you the most secure connection, but it's the most time consuming. I stripped the ends, twisted them up and wrapped them in electrical tape. Link to comment Share on other sites More sharing options...
quick4dr Posted January 27, 2012 Author Share Posted January 27, 2012 I'm going to solder cause its easy for me, but havent done stereo in ages, just wanted to double check the color to color matching. Link to comment Share on other sites More sharing options...
mr.hicksta Posted January 27, 2012 Share Posted January 27, 2012 Oh well that'll vary some with different head units. Do you have the manual? It should lay it out in there. Link to comment Share on other sites More sharing options...
angeltalin Posted January 27, 2012 Share Posted January 27, 2012 Check out this site, idk if it will help you with what you need http://ae64.com/Legacy-pinout.htm StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
mr.hicksta Posted January 27, 2012 Share Posted January 27, 2012 Oh yeah...SVXdc is the MAN. Definitely a good resource. Link to comment Share on other sites More sharing options...
angeltalin Posted January 27, 2012 Share Posted January 27, 2012 Hell yeah, with out him i wouldn't have ever installed my cleansweep and subwoofers Sent from my Droid Incredible 2 using Tapatalk StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
zmarko Posted January 27, 2012 Share Posted January 27, 2012 Did you get the i88 harness from SVXdc? Because it makes things A LOT easier. Link to comment Share on other sites More sharing options...
EJH Posted January 27, 2012 Share Posted January 27, 2012 solder + heat shrink tubing - it doesn't take that much more time to do it right! Link to comment Share on other sites More sharing options...
garbo41610 Posted January 28, 2012 Share Posted January 28, 2012 solder + heat shrink tubing - it doesn't take that much more time to do it right! +1. This should be the ONLY method. Or, instead of using the old twist and tape methed you could just use prechewed chewing gum. Link to comment Share on other sites More sharing options...
quick4dr Posted January 28, 2012 Author Share Posted January 28, 2012 bout 2 hours soldered and heat shrinker everything Link to comment Share on other sites More sharing options...
quick4dr Posted January 28, 2012 Author Share Posted January 28, 2012 DONE!!!!! I can play CD's again!!! Link to comment Share on other sites More sharing options...
