FJuan Posted January 30, 2012 Share Posted January 30, 2012 If you're taking out the sensor in the UP, you'll need to get the OHM resistor to prevent a CEL from popping up. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 2.2k ohm resistor found at radioshack for like $1. plug it in the egt connector and it's said and done. Link to comment Share on other sites More sharing options...
ChefRacer Posted January 30, 2012 Share Posted January 30, 2012 A proper tune will negate the CE from the egt sensor anyway. I've gone 10k since I went "stage II" and no ce light with just an empty egt plug. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 yeah. we're talking about just swapping up pipes. no tunes necessary for that. more work to disabled the cel than plugging in a resistor for just an uppipe change Link to comment Share on other sites More sharing options...
ChefRacer Posted January 31, 2012 Share Posted January 31, 2012 I was under the impression that he was just going to do the up and dp all at one time Link to comment Share on other sites More sharing options...
mbazzano88 Posted January 31, 2012 Author Share Posted January 31, 2012 ^^This is what I'll probably end up doing, since the DP has to come off anyway. Not sure if I'll go AP or open source yet, since I'm not too familiar with using my laptop to data log/whatnot. Link to comment Share on other sites More sharing options...
