kvn5 Posted January 24, 2012 Share Posted January 24, 2012 Hi all, i'm new here and have searching through the forums but cannot find a definite answer. Do JDM LGT or JDM (or USDM) spec b OEM springs lower the car if used on USDM struts (koni/kyb)? going off FAQ for OEM suspension thread, these springs are meant for bilsteins, which have a higher spring perch and thicker tophats. so assuming the front springs were installed on Konis/KYB, would it be safe to say the drop would be anywhere from 0.5"-0.75"?? If anybody is running JDM OEM springs with USDM struts, please post it up. Thanks, any info appreciated. Link to comment Share on other sites More sharing options...
