maxx189 Posted January 22, 2012 Share Posted January 22, 2012 Hello guys ! Here's my Spec.B 2007 setup: -Stock struts -Stock coils -Fender NOT rolled/pulled The wheel setup I am aiming for: Drag dr-31 18x9 +38 235/40/18 Do you think everything will fit fine ? if not , wich mod do I need ? thanks a lot, Max:) Link to comment Share on other sites More sharing options...
wpgspecb Posted January 22, 2012 Share Posted January 22, 2012 nope I have 18x8 +42 with 235/40/18 and i had to roll. You will need aggressive roll and perhaps a slight pull. Link to comment Share on other sites More sharing options...
wpgspecb Posted January 22, 2012 Share Posted January 22, 2012 Also use search function on legacygt.com Link to comment Share on other sites More sharing options...
maxx189 Posted January 22, 2012 Author Share Posted January 22, 2012 Also use search function on legacygt.com I'm not an idiot , but nobody seem to have the same answer to this fitment question. Some say it fit , some say it doesn't... Thank you for your answer.. Any other answer guys ? Link to comment Share on other sites More sharing options...
mwm5094 Posted January 22, 2012 Share Posted January 22, 2012 18x9 +38 will need fender work along with a pull. My 18x8.5 +48 still hit my fender when I turn on 225/40/18. Although you are at stock height so you may get away with it. Fit the wheels, if they hit, roll the fenders. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 22, 2012 Share Posted January 22, 2012 with stock suspension, you'll fit, but they are poking doubt you'll rub because the big gap, unless you are doing some rally jumps... simple Link to comment Share on other sites More sharing options...
