feersum dreadnaught Posted January 18, 2012 Share Posted January 18, 2012 OK - maybe a dumb question, and I did read the f-ing owners manual, to no avail. Issue is with key out, doors locked, and lights on the stalk turned off, the speedo / tach is staying lit up - at the same level as the daytime lighting. Help - I need to turn them off... thanks, Link to comment Share on other sites More sharing options...
authenticamd Posted January 24, 2012 Share Posted January 24, 2012 Are your 1st stage headlights on? Did you check the switch on top of the steering column? Link to comment Share on other sites More sharing options...
zmarko Posted January 24, 2012 Share Posted January 24, 2012 Did you check the switch on top of the steering column? Ding ding ding, that's my guess. Link to comment Share on other sites More sharing options...
