.... Posted January 17, 2012 Share Posted January 17, 2012 I have an 05 LGT, and the MPG display constantly jumps around and eventually finds its way to 99 MPG. I've read about a bunch of display problems in my searching, but nobody seems to have this one. It's always on, always bright, but never even close. I realize it's not that accurate, but I'd love to have it working properly. Any ideas? Link to comment Share on other sites More sharing options...
nemo Posted January 17, 2012 Share Posted January 17, 2012 You're looking at Instantaneous MPG, and not Average. Press the button. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
.... Posted January 17, 2012 Author Share Posted January 17, 2012 Hmm... I think I know what you're talking about. I'll try again when I drive the car next and try to describe the problem better if it doesn't work. Thanks. Link to comment Share on other sites More sharing options...
2.5GT_dude Posted January 18, 2012 Share Posted January 18, 2012 You're looking at Instantaneous MPG, and not Average. Press the button. x2 haha Link to comment Share on other sites More sharing options...
zmarko Posted January 20, 2012 Share Posted January 20, 2012 Bump. What's the consensus OP? Link to comment Share on other sites More sharing options...
.... Posted January 20, 2012 Author Share Posted January 20, 2012 The consensus is that my average MPG has never moved from 21.0 since I bought the car three months ago despite a mix of hard and gentle driving, and I still think that it's not working properly. The real-time MPG bounces around anywhere between 0 and 99 and does not seem to respond to throttle input, and continues to bounce around when I'm sitting still sometimes. Other times it settles on 99 which makes sense. Link to comment Share on other sites More sharing options...
.... Posted January 20, 2012 Author Share Posted January 20, 2012 Also the outside temp gauge is always at 19, day or night. I don't think it's actually been above 15 degrees in a week, and it's way lower at night. I've pretty much written the display off as a part that will never work right unless I pay to have it fixed, which is low on the priority list. Link to comment Share on other sites More sharing options...
wengermi Posted January 20, 2012 Share Posted January 20, 2012 On my 07 you have to reset the trip a or trip b for the mpg to reset Link to comment Share on other sites More sharing options...
.... Posted January 20, 2012 Author Share Posted January 20, 2012 I haven't tried that, but I will later. Thanks for the tip. Link to comment Share on other sites More sharing options...
zmarko Posted January 20, 2012 Share Posted January 20, 2012 The consensus is that my average MPG has never moved from 21.0 since I bought the car three months ago despite a mix of hard and gentle driving, and I still think that it's not working properly. The real-time MPG bounces around anywhere between 0 and 99 and does not seem to respond to throttle input, and continues to bounce around when I'm sitting still sometimes. Other times it settles on 99 which makes sense. Like noted above, reset your trip odometer (long press & hold on odometer button) and do some gentle driving on the highway (I would reset it WHILE driving 60 mph under light load on the highway just to verify). Your AVG MPG should come on after a mile or two. Don't watch the instant MPG, it'll just depress you (under normal driving). If you find that it's not working properly, you could check your local junk yards for one out of a wrecked car, or keep an eye on the classified section here for a display to pop up (you may have to purchase the whole cubby as they're not split up often). Link to comment Share on other sites More sharing options...
zmarko Posted January 20, 2012 Share Posted January 20, 2012 The consensus is that my average MPG has never moved from 21.0 since I bought the car three months ago despite a mix of hard and gentle driving, and I still think that it's not working properly. The real-time MPG bounces around anywhere between 0 and 99 and does not seem to respond to throttle input, and continues to bounce around when I'm sitting still sometimes. Other times it settles on 99 which makes sense. On my 07 you have to reset the trip a or trip b for the mpg to reset Like wengermi says, if you have 1000's of miles on your trip odometer, it'll take LOTS of driving a certain way to have an impact on your AVG MPG. Link to comment Share on other sites More sharing options...
.... Posted January 21, 2012 Author Share Posted January 21, 2012 On my 07 you have to reset the trip a or trip b for the mpg to reset That did it. Much appreciated. Link to comment Share on other sites More sharing options...
.... Posted January 21, 2012 Author Share Posted January 21, 2012 Like wengermi says, if you have 1000's of miles on your trip odometer, it'll take LOTS of driving a certain way to have an impact on your AVG MPG. I think you might be right about that, as it's still reading mid 20's and I don't think I'm getting that on the mountain roads that I drive. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 21, 2012 Share Posted January 21, 2012 zmarko is correct. It would've reset itself once the trip meter hit 10K. Link to comment Share on other sites More sharing options...
robitrice Posted January 24, 2012 Share Posted January 24, 2012 i always reset after every fill up and use Trip B for Oil Change intervals. Link to comment Share on other sites More sharing options...
zmarko Posted January 25, 2012 Share Posted January 25, 2012 i always reset after every fill up and use Trip B for Oil Change intervals. Same here. Link to comment Share on other sites More sharing options...
ChemicalWaste Posted January 28, 2012 Share Posted January 28, 2012 i always reset after every fill up and use Trip B for Oil Change intervals. I do the exact same thing. I thought that was basically what it was there for. Link to comment Share on other sites More sharing options...
