GTkansan Posted January 17, 2012 Share Posted January 17, 2012 So my rear Spec B bilstein that I swapped onto my 05 LGT a few years ago has started to make a weird 'rubber compressing' noise whenever there is some suspension travel. It happens in sharp corners, and over bumps and things like that. The dealer of course wants to replace everything under the sun 'to be sure' or whatever. I doubt the top hat can ever make sure a noise, so I should be fine just buying a new set of rear dampers and swapping them in right? Anyone have an alternate opinion? Also... Im thinking of going with Bilstein HD's in the rear as they should be a bit stiffer as well, any problems with them mixed with the front Stock Spec B struts? Link to comment Share on other sites More sharing options...
chutrain Posted January 17, 2012 Share Posted January 17, 2012 Are you sure it's from the struts? I would regrease the swaybar bushings as those are usually the culprit. How many miles on the rears? Link to comment Share on other sites More sharing options...
GTkansan Posted January 17, 2012 Author Share Posted January 17, 2012 About 30k on the rears. This is what the dealer says is the problem. Which of course makes me suspicious.... But the noise is very suspension travel dependent. Over small bumps there is no noise, but on longer suspension compressions the noise comes in. Link to comment Share on other sites More sharing options...
jayway Posted January 17, 2012 Share Posted January 17, 2012 I have the same bilstein's and my driver side rear was making a rattle/clunk when going over bumps or transitioning from a driveway to street. Took the assembly off and it turned out it was a loose top hat and after tightening there's no more rattles. Might want to look at that before you buy some new rear struts. Link to comment Share on other sites More sharing options...
GTkansan Posted January 17, 2012 Author Share Posted January 17, 2012 There is a bit of rattle/noise, but mainly its a really loud rubber noise. Its hard to explain... its also freezing cold in atlanta right now so taking off the rear to inspect is serious challenge... Link to comment Share on other sites More sharing options...
