RShaw Posted January 17, 2012 Share Posted January 17, 2012 Right now i have 245 40 r18s on them just because i had them, but i dont think i want to deal with the rubbing. I have done quite a bit of reading on here, but i would like to hear first hand that someone has fit 2xx xx r18 with this rim without rubbing to badly, i am prepared to roll the fenders a little. I know i could use a 225 40 but can i go any wider? And what would look best. Thanks! Link to comment Share on other sites More sharing options...
LegacyDan Posted January 18, 2012 Share Posted January 18, 2012 i have a 235/40/18 on an 18 x 8 and only rubs on full lock off the arch liner. thats sitting on jdm Bilsteins with STI pinks, about 20mm drop Link to comment Share on other sites More sharing options...
joedirtae09 Posted January 18, 2012 Share Posted January 18, 2012 ive got 225/40/18 on 18x8 wheels with stock struts and cobb springs... the cobb springs are a pretty agressive drop, no rubbing at all for me! Link to comment Share on other sites More sharing options...
chutrain Posted January 18, 2012 Share Posted January 18, 2012 245/40/18 all around on 18x8.5 ET48. Roll front and rear, and a very slight pull on the front fenders. Dropped on Swifts with Konis. Link to comment Share on other sites More sharing options...
LegacyDan Posted January 18, 2012 Share Posted January 18, 2012 245/40/18 all around on 18x8.5 ET48. Roll front and rear, and a very slight pull on the front fenders. Dropped on Swifts with Konis. wheels in question are 18 x 8, different setup Link to comment Share on other sites More sharing options...
chutrain Posted January 18, 2012 Share Posted January 18, 2012 Just stating that not much needs to be done if rubbing is the issue. On a 18x8 wheel, 235/40 would probably look best. Link to comment Share on other sites More sharing options...
whitetiger Posted January 18, 2012 Share Posted January 18, 2012 245/35/18 is closest to stock wheel diameter. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 18, 2012 Share Posted January 18, 2012 running 245/40/18 on 18x8 +48 ssr comps. Tires haven't rubbed since I raised the car up a bit and rolled the fenders. Link to comment Share on other sites More sharing options...
RShaw Posted January 19, 2012 Author Share Posted January 19, 2012 Hmm well before i buy new tires im gunna try to make the 245s work since its obviously possible. What do you guys do about the front inner fender liners? I was thinking i could either cut some of that rib out, or try to heatgun and flatten it. Im talking about where it meets the outside of the fender. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 19, 2012 Share Posted January 19, 2012 I never had to touch it. Link to comment Share on other sites More sharing options...
chutrain Posted January 19, 2012 Share Posted January 19, 2012 Don't need to touch the liner. If you roll the lips, don't go too far as you want enough to catch. Link to comment Share on other sites More sharing options...
RShaw Posted January 20, 2012 Author Share Posted January 20, 2012 Okay thats good. Link to comment Share on other sites More sharing options...
RShaw Posted January 20, 2012 Author Share Posted January 20, 2012 Stoplight, do you have any side profile pics of your car? Just so i can get an idea of what to set my height at. Usually i dont do this much research but my tophat is getting rebuilt so itl be a while before i can do anything. So for now all i can do is stare at my parked car and plan. Link to comment Share on other sites More sharing options...
RShaw Posted January 20, 2012 Author Share Posted January 20, 2012 Link to comment Share on other sites More sharing options...
RShaw Posted January 20, 2012 Author Share Posted January 20, 2012 Note the lack of coil overs in the rear. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 20, 2012 Share Posted January 20, 2012 This is about the best I can do from when I first put them on last year. The car sits just a little bit higher now than in this pic. I also have -1.5 camber up front and -1.2 in the rear. http://i284.photobucket.com/albums/ll37/jjbhoops30/SSRs_Black_zoomedout.jpg?t=1275354336 Link to comment Share on other sites More sharing options...
RShaw Posted January 20, 2012 Author Share Posted January 20, 2012 Thats pleanty low for my taste Link to comment Share on other sites More sharing options...
suds2250 Posted January 23, 2012 Share Posted January 23, 2012 I run 245/35/18 on 18x8 +48 rotas without any rubbing. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
90G60 Posted February 4, 2012 Share Posted February 4, 2012 I run 245/35/18 on 18x8 +48 rotas without any rubbing. Are you on stock springs? Link to comment Share on other sites More sharing options...
lil_z_33 Posted February 6, 2012 Share Posted February 6, 2012 I run 245/35/18 on 18x8 +48 rotas without any rubbing. suspension setup??? Link to comment Share on other sites More sharing options...
