Ohitsspencer Posted January 16, 2012 Share Posted January 16, 2012 Got up this morning and went to go start my car, but it followed by having absolutely nothing happen. I couldn't even unlock my doors with the key fob. I took my battery in to WalMart where it was originally purchased 5 months ago to have it tested. It tested out better than it should have. Does this sound like a bad alternator to you guys? If so, anyone local have any experience in swapping them out? I found a How-To-ish, but it would be nice for some local tips or help. Any info would be much appreciated. Thanks! Spencer Link to comment Share on other sites More sharing options...
mwiener2 Posted January 16, 2012 Share Posted January 16, 2012 Alternator has nothing to do with starting the car. If the battery was fine, then you had a bad connection to the battery if you couldn't even unlock he doors. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
keithk831 Posted January 16, 2012 Share Posted January 16, 2012 ...WalMart where it was originally purchased 5 months ago... This is your problem. Link to comment Share on other sites More sharing options...
Ohitsspencer Posted January 16, 2012 Author Share Posted January 16, 2012 Alternator has nothing to do with starting the car. If the battery was fine, then you had a bad connection to the battery if you couldn't even unlock he doors. That's what I was thinking. When I reinstalled the battery, it was getting power(unlocked, interior lights, dash lights, etc.) but as soon as I tried to start it, it completely dies again. Could it just be the connectors? When I replaced the battery in August, the connectors were really corroded, but I had sprayed stuff on it and it cleaned it up. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 16, 2012 Share Posted January 16, 2012 if you are sure the connections are good, then walmart sucks at life and didn't test the battery properly and it is bad. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Ohitsspencer Posted January 16, 2012 Author Share Posted January 16, 2012 I could try replacing the connectors. Have you done this before? Is it pretty self explanatory? Link to comment Share on other sites More sharing options...
mwiener2 Posted January 16, 2012 Share Posted January 16, 2012 No, I think they are crimped on. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
keithk831 Posted January 16, 2012 Share Posted January 16, 2012 I could try replacing the connectors. Have you done this before? Is it pretty self explanatory? Just make sure there's metal touching metal on the terminals. If there's rust or battery acid buildup, get a metal wire brush and clean it off. Several years ago I had a Wal-Mart battery go bad in less than a year. It was their "top of the line" one, too. Link to comment Share on other sites More sharing options...
Ohitsspencer Posted January 16, 2012 Author Share Posted January 16, 2012 I got the car to start about 5 minutes ago. I am still letting it run, then I will attempt to start it again. I had unhooked the battery again this morning, cleaned it off the best I could with some steel wire. It took 3 tries to get it started. When I rev it now at idle, it'll drop to where it's almost dead, and then it will go back up to idle revs. I will turn it off and try starting it up again here in a few minutes. Link to comment Share on other sites More sharing options...
Ohitsspencer Posted January 16, 2012 Author Share Posted January 16, 2012 Just took it out for a drive, and it did fine. Didn't fall do low on the RPM scale, and it didn't have any issue starting up. I will update if anything new happens. Thanks a lot for your guy's help! Link to comment Share on other sites More sharing options...
