Reckoner Posted January 15, 2012 Share Posted January 15, 2012 So I sold my legacy because of financial problems and Now im going to buy another 95 L sedan and wanted to know if i bought these wheels/tires would fit properly without rubbing on anything I tired to look up and find if they would fit but had no luck Enkei Performance EDR9 16" 16x7 Offset: +45mm Backspacing: 5.70" Bolt Pattern: 5-100 Rec. Tire Size:205/50-16 Weight: 18.6lbs. Going to use the recommended tire size Link to comment Share on other sites More sharing options...
johnegg Posted January 15, 2012 Share Posted January 15, 2012 the wheels should fit fine. the tires are a little smaller than the stock tires on a 95 lego, about 0.5%. this means when the speedo says you are going 70 you will really be going 69.64 mph. assuming the speedo is accurate with stock tires. go for it. Link to comment Share on other sites More sharing options...
Reckoner Posted January 15, 2012 Author Share Posted January 15, 2012 the wheels should fit fine. the tires are a little smaller than the stock tires on a 95 lego, about 0.5%. this means when the speedo says you are going 70 you will really be going 69.64 mph. assuming the speedo is accurate with stock tires. go for it. Sweet thanks and I might be buying a 04+ sti instead because I found a REALLY good deal on one and have always wanted one so if i buy it I'll only own it for like 3 months before i sell it so i dont get into trouble Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 16, 2012 Share Posted January 16, 2012 Just stay out of trouble. Link to comment Share on other sites More sharing options...
Reckoner Posted January 16, 2012 Author Share Posted January 16, 2012 Just stay out of trouble. Well hopefull I can get the sti fix it drive it for a little while then sell it and use the money to finance my legacy build Link to comment Share on other sites More sharing options...
