lostkhan Posted January 15, 2012 Share Posted January 15, 2012 I recently changed oil. After driving more than 500 miles, car started dripping alot of oil and there is smoke coming out of the hood every time i drive the car more than 10 minutes. I have no idea what caused this, i haven't clearly looked underneath the car yet. Before the oil change, the oil used to drip but very little, which i thought was normal for a 15 year old car. What do you guys think can cause this? Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted January 15, 2012 Share Posted January 15, 2012 Where was the oil dripping from? If it is dripping on the y pipe most likley rear seal, could be valve cover gasket just depends on where it is leaking Link to comment Share on other sites More sharing options...
lostkhan Posted January 15, 2012 Author Share Posted January 15, 2012 Have to idea yet. Will be taking it to the mechanic tomorrow. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted January 15, 2012 Share Posted January 15, 2012 Hopefully it is not the rear main seal cause that can be kind of expensive because the motor has to be pulled. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted January 15, 2012 Share Posted January 15, 2012 I hope yours is something else i have to get mine into the shop because of the rear seal in the next few weeks.When i stop all the smoke coming from under the hood because of the oil leaking on my exhaust makes it look like my car is gonna catch on fire.haha Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 15, 2012 Share Posted January 15, 2012 I bet we can narrow it down to 15 or 20 or so things from all the info you gave us, lol. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted January 15, 2012 Share Posted January 15, 2012 Link to comment Share on other sites More sharing options...
johnegg Posted January 15, 2012 Share Posted January 15, 2012 year, model, trans, miles, engine????????? Link to comment Share on other sites More sharing options...
LegacyLou Posted January 15, 2012 Share Posted January 15, 2012 I also started to smell oil burning, It turned out to be a leak in the low pressure power steering hose. Link to comment Share on other sites More sharing options...
lostkhan Posted January 16, 2012 Author Share Posted January 16, 2012 year, model, trans, miles, engine????????? 1996 Legacy L Automatic with 136k on it. Mechanic said the timing belt, water pump has to be changed and the oil is dripping from some seals close to the crankshaft pulley and that can break the belts. I have no idea where he was leading the problem to. Ill be going to another mechanic and see if he can give me a straight answer. Link to comment Share on other sites More sharing options...
mustangendsley Posted January 16, 2012 Share Posted January 16, 2012 Valve cover gasket! maybe. Link to comment Share on other sites More sharing options...
jazzymt Posted January 16, 2012 Share Posted January 16, 2012 On that car I would suspect the valve cover first (happened to me in my 1997 Outback), but generally that shows up as oil all over one of your wheels/wheel wells. If it's really from the front timing belt area - it's probably the oil pump/crank seal. [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 17, 2012 Share Posted January 17, 2012 1996 Legacy L Automatic with 136k on it. Mechanic said the timing belt, water pump has to be changed and the oil is dripping from some seals close to the crankshaft pulley and that can break the belts. I have no idea where he was leading the problem to. Ill be going to another mechanic and see if he can give me a straight answer. Your mechanic is probably being honest with you. It could be your valve cover gaskets, oil pump seal, cam seals, or crankshaft seal... But if you are replacing your timing belt and water pump, then you can replace all of those seals at the same time and be good to go for a long time. Replace your camshaft support o-rings too while you are at it. None of this stuff is too hard to replace on your own and you will save a bunch of money. All of the parts/seals are inexpensive. We are glad to help if you decide to do it on your own. Link to comment Share on other sites More sharing options...
00LegacyL Posted January 17, 2012 Share Posted January 17, 2012 Probably the front seal, i had the same problem and just got my seal/timing belt and pump done. Gettin her back tomorrow Link to comment Share on other sites More sharing options...
JayP79 Posted January 28, 2012 Share Posted January 28, 2012 i also had a oil leak ended up being a cam seal replaced those as well as the crank seal,drivers cam o-ring ,water pump and all timing parts. after than i noticed the smell of oil still looked around and it ended up being the cam o-ring on the passenger side rear of the motor. Link to comment Share on other sites More sharing options...
