98Wagon Posted February 3, 2012 Author Share Posted February 3, 2012 Agreed! I'll bet I was only maybe four teeth away from real damage! Link to comment Share on other sites More sharing options...
kt240240 Posted February 4, 2012 Share Posted February 4, 2012 I have had a fuel pump problem and it still threw a code, one easy thing to check is the MAF sensor, try disconnecting it and starting the car, if it runs that's probably the problem, its probably the easiest thing to check, then I would go to fuel pressure gauge. Timing is probably the last thing I would check. Its very rare that the timing would just go bad like that unless the belt snapped which would of killed the engine immediately Link to comment Share on other sites More sharing options...
98Wagon Posted February 5, 2012 Author Share Posted February 5, 2012 I have had a fuel pump problem and it still threw a code, one easy thing to check is the MAF sensor, try disconnecting it and starting the car, if it runs that's probably the problem, its probably the easiest thing to check, then I would go to fuel pressure gauge. Timing is probably the last thing I would check. Its very rare that the timing would just go bad like that unless the belt snapped which would of killed the engine immediately I guess you didn't see my last 2 posts or my pictures. it was timing belt, but not broken- just almost. Link to comment Share on other sites More sharing options...
