lulzcow Posted January 6, 2012 Share Posted January 6, 2012 I am going to be doing an install of coilovers and my stainless steel brakelines soon, and I know I need to get new calipers....so I figured while I am at it I might as well do the WRX brake swap as well. Curious, what would I need to buy when I do this swap? I am looking to buy all of these new from an auto store... So would I just purchase the 03? WRX front caliper set, 03? WRX front rotor set, and 03? WRX front pad set? Link to comment Share on other sites More sharing options...
lulzcow Posted January 6, 2012 Author Share Posted January 6, 2012 I was hoping these rotors perhaps: http://jbautosports.com/ebc_brakes/ebc_brake_rotors_usr_slotted_rotors/usr972/i-440419.aspx Maybe this for the calipers: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Semi-Loaded-Brake-Caliper-Beck-Arnley_99985574-P_1162_R|GRPBRHYAMS_____ And probably something EBC for the pads.... Would this work? Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 6, 2012 Share Posted January 6, 2012 I would like to know too. Hey lulz, are you going to replace your rears as well? H6 swap? Not to threadjack, but to keep all this in one place... if anyone has an opinion regarding buying used calipers and rebuilding them vs. just buying new it would be appreciated. Link to comment Share on other sites More sharing options...
subikid90 Posted January 6, 2012 Share Posted January 6, 2012 They is a thread on here from a guy name Cameron with a black wagon that documented the swap very well. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
lulzcow Posted January 6, 2012 Author Share Posted January 6, 2012 Monkey, I will eventually but right now I will only do the fronts as they need fixed sooner than later. Subikid, thanks, found it!: http://legacygt.com/forums/showthread.php/2nd-gen-lgt-brake-upgrades-wrx-front-and-h6-rear-154702.html Link to comment Share on other sites More sharing options...
lulzcow Posted January 6, 2012 Author Share Posted January 6, 2012 Looks like besides the rotors, pads, and calipers, all that is needed is the appropriate caliper brackets for whichever style brake you will be running! Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 6, 2012 Share Posted January 6, 2012 Yeah, you can easily swap H6 rotors using your original rear calipers. Here is another good (lol) question. Semi-loaded vs. loaded calipers? Sometimes the loaded calipers are cheaper, but is it worth it? With loaded calipers you get pads, but if you want to get fancy pads then why bother. Link to comment Share on other sites More sharing options...
subikid90 Posted January 6, 2012 Share Posted January 6, 2012 ^ Yes you are correct. It is a very easy and cheap swap. Not to discourage but I have heard it is not night and day because the master cylinder on most subaru's are kinda soft. But since you need new stuff anyways it cannot hurt. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 6, 2012 Share Posted January 6, 2012 Well, what about getting a master cylinder brace? They are about $80 or so. Wondering if it is worth it. Easy install though. Link to comment Share on other sites More sharing options...
subikid90 Posted January 6, 2012 Share Posted January 6, 2012 I dont think the wrx/sti brace fits our car. I guess they would be easy to fabricate. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 6, 2012 Share Posted January 6, 2012 Grimmspeed makes one that fits our leggys: http://www.grimmspeed.com/catalog/product_info.php?cPath=144&products_id=217 edit: that link won't take you directly to the part. I just googled 'grimspeed master cylinder brace legacy 95' and it was the second link. Link to comment Share on other sites More sharing options...
subikid90 Posted January 6, 2012 Share Posted January 6, 2012 I did not know about that one. I like it! -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
eekay Posted January 7, 2012 Share Posted January 7, 2012 What size WRX brakes are you talking about doing here? Are they even going to make a significant difference from the stock brakes? My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
Baddog Posted January 7, 2012 Share Posted January 7, 2012 From an L to a WRX with a decent brake pad. You will notice the difference. From a GT over to a WRX not as much. Link to comment Share on other sites More sharing options...
eekay Posted January 7, 2012 Share Posted January 7, 2012 Gotcha'. Didn't know it was an L. Shoulda looked at his info! My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
jamal Posted January 7, 2012 Share Posted January 7, 2012 I have the wrx/h6 brakes. How easy the swap is depends on year. Front: If you have a 97-99 GT, then all it takes is the bracket and rotor- calipers and pads are the same. If you have a 90-96, or a car with 1-pots, you need everything. Rear: The rear caliper and bracket are different on the 2nd gens than the ~99/00+ models. The older cars have a bracket with a pin sticking out of it that goes through the caliper, with a bolt on the other end. If you want to do the H6 upgrade you have to get everything- caliper, bracket, rotor, and pads. You also have to swap/remove the front dust shield and remove/bend/cut the rear dust shield. Link to comment Share on other sites More sharing options...
