thegamettt Posted December 30, 2011 Share Posted December 30, 2011 Its coming from one of the two hoses that runs up between the battery and the wiper fluid. Directly behind the headlight. I can't see the hose after it runs into the fender but i stuck my hand in there and can feel the hose soaked in oil. What is it? is it safe to drive for a few days before i can get to the mechanic? Link to comment Share on other sites More sharing options...
frank_ster Posted December 30, 2011 Share Posted December 30, 2011 what color is the oil ? i would think the only thing there is automatic tranny fluid if its an automatic. i would check engine and tranny fuild levels and take it easy on the car Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
thegamettt Posted December 30, 2011 Author Share Posted December 30, 2011 I think you're right, its some sort of oil, but cleaner than the motor oil. I found the AT dipstick, how do i add more? Link to comment Share on other sites More sharing options...
bmx045 Posted December 30, 2011 Share Posted December 30, 2011 you fix the problem before adding more. you fill the tranny through the dipstick hole, get a funnel with a straw Link to comment Share on other sites More sharing options...
frank_ster Posted December 30, 2011 Share Posted December 30, 2011 NOTICE THERE ARE TWO TRANNY DIPSTICKS ON AUTO CARS !!! ONE IS FOR THE FRONT DIFFERENTIAL !! THAT HAS GEAR OIL friendly reminder you want the had to get to one on the left side ie LH DRIVERS SIDE OF NORTH AMERICAN CARS. just cuz this was an issue to some one before on here Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
thegamettt Posted December 30, 2011 Author Share Posted December 30, 2011 NOTICE THERE ARE TWO TRANNY DIPSTICKS ON AUTO CARS !!! ONE IS FOR THE FRONT DIFFERENTIAL !! THAT HAS GEAR OIL friendly reminder you want the had to get to one on the left side ie LH DRIVERS SIDE OF NORTH AMERICAN CARS. just cuz this was an issue to some one before on here Thanks man, I believe I found the right one, I pulled it from the back of the engine on the drivers side. The dipstick handle is yellow with a loop right? I'm pretty sure its just the hose because I just had that head light repaired due to a minor fender bender. The hose must have got pinched or something. I can't make it to the mechanic today so I just want to make sure theres enough fluid in it to get around until then. I won't be driving it much til then. Link to comment Share on other sites More sharing options...
bmx045 Posted December 30, 2011 Share Posted December 30, 2011 drivers side is tranny, passenger side is diff Link to comment Share on other sites More sharing options...
