2furious Posted December 26, 2011 Share Posted December 26, 2011 Folks in Utah... I just moved to Salt Lake and am wonder what the rule is about the registration and emission. My LGT is in Stage 2 with Cobbs catted down pipe and stuffs like that. I've talked with a guy in town and he can do the emission without sniffing the exhaust in his shop. Can I pass with current map I got? Any comment and advice will be appreciated. Thanks. J From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
Guest fnp_tuning Posted December 26, 2011 Share Posted December 26, 2011 It's an obd2 scan with a visual check, if you go to a lazy shop and your readiness monitors are good to go you should do fine. They have been handing out a lot of tampered notices lately, which means the exhaust isn't stock. So no cels, monitors a go and a lazy shop tech and you should be fine. Fyi I passed catless with a very very loud exhaust 2x years in a row no problems. Link to comment Share on other sites More sharing options...
doccrowley Posted December 28, 2011 Share Posted December 28, 2011 Jiffy Lube Bountiful passed me 2 years in a row, Catless exhaust and very loud exhaust also. You should be fine. Then again, Jiffy Lube Bountiful bought me a tranny for my suburban because they are so lazy and unqualified. Heard that Wheel Works off of Main Street SLC was also Subie friendly. Link to comment Share on other sites More sharing options...
2furious Posted December 28, 2011 Author Share Posted December 28, 2011 Thanks Folks. I will check those places. From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
2furious Posted January 10, 2012 Author Share Posted January 10, 2012 Should I run a different map for the emission test or tuned map is okay? From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
S402 Posted January 10, 2012 Share Posted January 10, 2012 should be good with a tuned map Link to comment Share on other sites More sharing options...
2furious Posted August 3, 2012 Author Share Posted August 3, 2012 I passed the emission at one of the Jiffy Lubes and my 05 is not due for the safety inspection until next year. I was told she would not pass the inspection due to the tint. I was offered to get it removed and installed one within the legal limit from the Jiffy guy. How do you guys take care of the tint issue? From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
Guest fnp_tuning Posted August 4, 2012 Share Posted August 4, 2012 Remove and replacing seems to be the easiet remedy. Link to comment Share on other sites More sharing options...
