browningr6 Posted December 25, 2011 Share Posted December 25, 2011 http://www.ebay.com/itm/XXR-522-18-18x9-5-5x100-5x114-3-38-CHROMIUM-BLACK-WHEELS-SUBARU-WRX-STI-350Z-/320812750197?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4ab1ee1575 Has anybody bought any of these ebay wheels? And i am sure this has been covered but what all would i have to do to run that offset/width? Right now i am lowered on a pro kit and am not really planning on going any lower because this is my dd and we do get a little bit of snow along with the roads around here being pretty bad. Link to comment Share on other sites More sharing options...
frank_ster Posted December 25, 2011 Share Posted December 25, 2011 well there "hot" Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
browningr6 Posted December 25, 2011 Author Share Posted December 25, 2011 lol yea i noticed that! by the way did that computer come in? I meant to send you a pm the other day and make sure it made it Link to comment Share on other sites More sharing options...
frank_ster Posted December 25, 2011 Share Posted December 25, 2011 yep .. thanks Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
joeblow Posted December 25, 2011 Share Posted December 25, 2011 Lug Nuts, Tires, Valve Stems, and Hub Centric Rings are also available but sold separately. Check out our eBay store for these items. ^There are a number of guys on here running XXRs, I would suggest PMing one of the vendors (there used to be one, but I'm not sure who it was) that sells them for ^this^ reason. Customer service. A lot of them will include a set of "tuner lugs," hub centric rings, and valve stems at little to no extra cost. As far as fitment, an 18x9.5 +38 may require some fender rolling and front camber to fit if you're lower than stock. Also, 24.7lbs is ridiculously heavy. You'll definitely notice a change in your steering response, and may notice a change in acceleration from a dead stop. I went from a 23lb wheel to 18.5lb ones and it was a noticeable change in turn-in response. But, they are a good looking wheel. I like the concave design and the finish. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
browningr6 Posted December 25, 2011 Author Share Posted December 25, 2011 Ok thanks I don't really want to mess the camber so i might just go with something a little less wide. I am with you I have went from heavier wheels to light wheels on other vehicles and it was a noticable difference in acc. Link to comment Share on other sites More sharing options...
bmx045 Posted December 27, 2011 Share Posted December 27, 2011 go with 18x8 or 8.5 and you'll be fine with oem alignment spec and 225/40 18's Link to comment Share on other sites More sharing options...
