TurboLegacy_pdx Posted June 23, 2005 Share Posted June 23, 2005 Hi guys, Its only been about 1 week since I took delivery of my LGT, I'm already having door ajar sensor problems. Started about 1 day ago, whenever I take a left turn, the right passenger door ajar waring light would come on, on the dash display. At first, I was kinda worried, so I would pull over to open and re-close the door. Then the light would go off. But it would come back on again as soon as I take any sort of left turn with just a silght acceleration. Today samething happened. While I was at my works parking lot, I tested the door while I was parked. Whenever I just put a little bit of force on the door from the inside pushing out, the light would come on. Then whenever I pull on the door handle inwards, the light would go off. Has anyone else experience this issue? Or is this normal? There doesn't appear to be an issue with the door not closing and shut all the way, but the sensor seems to be overly sensitive. I'll bring the car into the dealership as soon as I can of course. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 23, 2005 Share Posted June 23, 2005 It's broken. I'd say take a look in the door and see if anything obvious is awry. Link to comment Share on other sites More sharing options...
