Deer Killer Posted November 25, 2011 Share Posted November 25, 2011 Even coilovers I see advertised the a 1"+ drop. The do not say if this is at the top or bottom of coilover adjustment. Lowering my car is just not an option. I had spring helpers installed in the rear springs, which did actually stiffer up the rear by about 10%, but they last about a year before the spring cuts the helper in half.. Link to comment Share on other sites More sharing options...
Bolksey85 Posted November 25, 2011 Share Posted November 25, 2011 Depending on your budget, I imagine RCE/RaceComp would custom valve and spring you a set of Tarmac 1's. They should be able to set them to OEM ride height with a stiffer spring and/or more aggressive valving. Link to comment Share on other sites More sharing options...
Deer Killer Posted November 29, 2011 Author Share Posted November 29, 2011 They don't even advertise their spring rates, no sale. The suspension aftermarket seems to be quite terrible - impossible to get accurate numbers or reviews. As far as I can tell I would want STI pinks on my stock dampers. People say the stock dampers can't handle them, well according to any info I can find, the rears are only 14% stiffer. I ran 10% stiffer with no damping issues. IMHO the USDM car is overdamped and undersprung. *shrug* Link to comment Share on other sites More sharing options...
ultimakf7 Posted November 29, 2011 Share Posted November 29, 2011 Weld bars between the subframe and the control arms Link to comment Share on other sites More sharing options...
scoobyscoodle Posted November 29, 2011 Share Posted November 29, 2011 They don't even advertise their spring rates, no sale. This is because you have the ability to select your rates. Stock rates on the T1's are 400lb/400lb but I believe the dampers can handle up to a 550lb rate max. Anything above that is AST territory. Link to comment Share on other sites More sharing options...
