DirtyDan Posted November 21, 2011 Share Posted November 21, 2011 I did not get the navigation supplement with the car. I have done several searches, but I haven't found the actual instructions, telling how to change the clock. Can someone point me in the right direction? Link to comment Share on other sites More sharing options...
bmx045 Posted November 21, 2011 Share Posted November 21, 2011 hit menu and then navigation setup, once you change the nav clock it will change your gauge cluster clock within a run cycle or two. Link to comment Share on other sites More sharing options...
DirtyDan Posted November 21, 2011 Author Share Posted November 21, 2011 I couldn't get to the nav clock. It gave me the calendar, but never the clock settings. Link to comment Share on other sites More sharing options...
bmx045 Posted November 21, 2011 Share Posted November 21, 2011 you're doing it wrong. Seriously, you press menu, and navigation setup, and there's a clock button. Seriously. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 I couldn't get to the nav clock. It gave me the calendar, but never the clock settings. I'm with you Dan, I seem to recall it being a PITA in my 09 last spring. I played the other day with it, but it wasn't that easy. You would think the clock would be reset on it own. After all my electronic thermostat in my living room reset itself. Stupid Subaru Engineers. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted November 21, 2011 Share Posted November 21, 2011 It's literally a 1in x 1inch button that say "Set Clock" under navigation setup, you touch it, with your finger. Link to comment Share on other sites More sharing options...
DirtyDan Posted November 21, 2011 Author Share Posted November 21, 2011 http://cdn.head-fi.org/d/d7/1000x500px-LL-d790e245_doh-homer-simpson.jpg I was making that a lot harder than it was. Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 I'll try that when I get home tonight. I haven't driven the car since the time changed. I didn't want tomess anything up by driving it with the wrong time set... No not really. LOL Hey what happens if I get soap on the interkooler... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DirtyDan Posted November 21, 2011 Author Share Posted November 21, 2011 My mistake was using the setting button on the far right. I still didn't see how to actually change the time, I just turned off the daylight savings. But, that's all I wanted to do. I mean who uses their car for a calendar reminder? That's what I have a Blackberry for. If I had the supplemental manual, I might find something useful in it. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 I remember opening all the maunals that came with the car, it was still hard to find. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dsickles Posted November 22, 2011 Share Posted November 22, 2011 the real question here is why the gauge cluster allows you to access a time setting menu, change the time, and hit ok, only to not do a darn thing. Silly Subaru Link to comment Share on other sites More sharing options...
