GoSix Posted November 19, 2011 Share Posted November 19, 2011 Anyone in the Sacramento area have an AccessPort OBD-II cable I can borrow for a day? I have version 1. I'm not sure if the cable changed in version 2. When attempting to change my base map for upcoming smog (why I need to do it is a whole other story), My Version 1 Accessport stopped at Initializing ECU..., then would cycle back to "turn car off and on and press OK"...then repeat. Checking these interwebs, it looks like people were able to fix this by getting a new cable. It's the weekend and with Thanksgiving coming up, it might be a while before I can have one ordered and delivered in a timely manner . Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
Wang Lung Posted November 20, 2011 Share Posted November 20, 2011 Call me, I'm in Antelope. 769-3324 Link to comment Share on other sites More sharing options...
nm Posted November 20, 2011 Share Posted November 20, 2011 What does the AP end of your cable look like? I have one for an AP2, but it is not a USB or serial port, but the more recent one with the clip. Also, how stupid is it that the AP can't read the readiness code? Link to comment Share on other sites More sharing options...
GoSix Posted November 20, 2011 Author Share Posted November 20, 2011 Call me, I'm in Antelope. 769-3324 Thanks Wang, I left you a voicemail! What does the AP end of your cable look like? I have one for an AP2, but it is not a USB or serial port, but the more recent one with the clip. Also, how stupid is it that the AP can't read the readiness code? Mine looks like the old serial ports or "game" ports as we used to call them. And yeah, it's pretty lame we can't read the readiness code. I need to reflash the base map because for some strange reason I got a "P0137 - Rear O2 Sensor Circuit Low Voltage" after I swapped back to stock DP. The Cobb base maps are supposed to override that P code. Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
nm Posted November 20, 2011 Share Posted November 20, 2011 That's not mine unfortunately. I do have a regular code reader if you just want to clear the code. I now have my readiness code and will be getting smogged tomorrow. Link to comment Share on other sites More sharing options...
GoSix Posted November 21, 2011 Author Share Posted November 21, 2011 Nah. This CEL can't be cleared without override. I need to change the map. Good luck on the smog, and post results! Still looking for a Rev 1 AP cable... Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
GoSix Posted November 21, 2011 Author Share Posted November 21, 2011 Just called Cobb. They asked me if my test mode connectors are hooked up before I changed the base map. Ugh, it's been years! I totally forgot! Gonna try that tonight. Hopefully I won't need to borrow one after all. Will post when done. Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
GoSix Posted November 22, 2011 Author Share Posted November 22, 2011 Okay, I didn't need a new cable after all. I got the Cobb Stage 1 base map loaded. I hope that will fix the "P0137 - Rear O2 Sensor Circuit Low Voltage" CEL I had. However I had a Cobb map in there to begin with; so I should not have triggered that after swapping down pipes. Fingers crossed it doesn't CEL again when I get the readiness code. Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
nm Posted November 22, 2011 Share Posted November 22, 2011 I don't know if the Cobb stg 1 map suppresses that as on stg 1 you should have a rear 02 sensor. Link to comment Share on other sites More sharing options...
GoSix Posted November 22, 2011 Author Share Posted November 22, 2011 I don't know if the Cobb stg 1 map suppresses that as on stg 1 you should have a rear 02 sensor. Oddly enough, it triggered on a Stage 2 map, but it was custom from GST Motorsports. Even then, I'm not sure why it went off until after the stock pipe was replaced. On Cobb's site, the notes for the Stage 1 Map from Cobb indicate it overrides P0137, pdf. Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
