wannalegacy Posted December 8, 2011 Author Share Posted December 8, 2011 Really?.. So how does that work then?.. Does it just UP every mode? Like, theI mode becomes the old S# mode?. The S mode becomes a S## mode?, and the S# mode becomes a S### mode?. Lol! When the ECU is flashed your car will perform more efficiently as a whole while retaining all the functionality of SI drive. Link to comment Share on other sites More sharing options...
wheelsbreakloose Posted December 9, 2011 Share Posted December 9, 2011 When the ECU is flashed your car will perform more efficiently as a whole while retaining all the functionality of SI drive. Thanks!! That's what I was wondering about. Very good to know!! Now I just gotta save up the cash and get me one! Link to comment Share on other sites More sharing options...
brawline Posted December 9, 2011 Share Posted December 9, 2011 Here is how the SI drive works. and is the same when you go stage 1 or 2 with the cobb map. I think when pro-tuned the tuner can adjust differently as well but not 100% on that. SI-Drive: Three Engines in One The new SI-Drive system allows the driver to maximize engine performance, control and efficiency by choosing from among three selectable modes – “Intelligent”, “Sport” and “Sport Sharp” – using a rotary dial on the center console. The SI-Drive controls the electronic throttle system’s response and fuel and ignition curves to modify engine torque characteristics, changing the performance character of the car in each mode. With "Intelligent" mode selected, the system reduces engine torque and maximum power and switches to a more relaxed throttle response curve. Intelligent mode is an ideal choice for smoother response while commuting in traffic, for example, where it can also help boost fuel efficiency by up to 10 percent. In addition, "Intelligent" mode’s more relaxed responses and lower torque output make it an ideal complement to the low-traction surface driving safety provided by the Subaru Symmetrical All-Wheel Drive System. In “Sport” mode, the performance of the 2.5 GT spec.B (and other 2007 turbo Legacy and Outback models) is similar to the 2006 model, with quick throttle responses and powerful, linear acceleration. The linear acceleration characteristic of this versatile mode makes it ideal for driving on freeways and suburban streets or for climbing mountain roads. In “Sport Sharp” mode, SI-Drive modifies the engine’s electronic throttle mapping to deliver lightning quick throttle response and more power sooner. Delivering maximum driving enjoyment, this mode is ideal for tackling twisty roads and for merging or overtaking other vehicles on the highway with confidence. On 2007 Legacy and Outback models equipped with the 5-speed automatic transmission (not available on Legacy 2.5 GT spec.B), SI-Drive also changes the transmission’s shift patterns. It will hold each gear longer through the rpm range and downshift more quickly under hard acceleration, depending on the mode selected. The SI-Drive system includes instrument panel displays that allow the driver to monitor performance. The multi-information display located in the tachometer face – in addition to providing trip computer functions – denotes the selected SI-Drive mode and provides an active torque curve display. When “Intelligent” mode is selected in vehicles with a manual transmission, a shift-up indicator blinks to signal the optimal shift point for maximum fuel efficiency. Read more: http://www.worldcarfans.com/10604187286/subaru-intelligent-drive-si-drive#ixzz1g55Upfz0 Link to comment Share on other sites More sharing options...
