bmx045 Posted December 12, 2011 Share Posted December 12, 2011 if it idles rough during cold starts then subsides once the engine is up to temp, its the intake manifold gaskets. k Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted December 12, 2011 Mega Users Share Posted December 12, 2011 my rough idle is not due to cold weather start ups or anything cold temp related. this is a constant rough idle but i should mention that it's not as rough as some describe their's to be. the tachometer on mine doesn't appear to move at all however while sitting and idling (maybe at a stop light or in a parking spot) you feel it in the seats and doesn't feel normal at all. i feel like there's something i can do but don't want to start replacing o-rings or anything else unless i know it's a good bet it might be the problem. FYI my spark plugs are performing properly and the idle doesn't change based on which company fuel i go with... thoughts? Justin if its not your MAF then most likely intake manifold gasket "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted December 12, 2011 Mega Users Share Posted December 12, 2011 and maybe if you didnt let your GF drive your car you wouldnt be droppin clutches left and right "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
upshiftn Posted December 13, 2011 Share Posted December 13, 2011 and maybe if you didnt let your GF drive your car you wouldnt be droppin clutches left and right its a soar subject Link to comment Share on other sites More sharing options...
Refuge Posted May 1, 2012 Share Posted May 1, 2012 Damn leaks! How do you fix exhaust and intake "manifold" leaks? Link to comment Share on other sites More sharing options...
vet Posted May 1, 2012 Share Posted May 1, 2012 Sounds crazy but my idle cleared up quite a bit after replacing my original battery, yes almost 6 yrs old, a month or so ago. I assumed it was due to the ecu resetting but the idle has stayed much smoother for a month now. The battery never failed on me but I'm wondering if constant low juice could have been affecting spark, coil packs, etc. Car always ran great above idle speed. Link to comment Share on other sites More sharing options...
BGPKR Posted May 1, 2012 Share Posted May 1, 2012 I'm hope replacing the cracked uppipe will fix my problem... Link to comment Share on other sites More sharing options...
