BAC5.2 Posted March 21, 2012 Share Posted March 21, 2012 There is no argument... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
HoosierDaddy2 Posted March 21, 2012 Share Posted March 21, 2012 I'm FAIRLY sure that you have no idea what you are talking about. ... and after waaay too many hours researching this yesterday , I'm fairly certain you were correct in that ! LOL (and BiggTdogg too) Man , there is a $hit ton of misinformation out there on this and very few people that were correct give any background as to why they are. If nothing else , thanks for taking me to school on this. I'll try to be less ignorant in the future. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted March 21, 2012 Share Posted March 21, 2012 I learned the hard way. Bought a set of OZ Mito Modulars for my Z32 off of a FD RX-7 owner. Bolt pattern was good, offset was way too high, so I hit suspension components up front. Did more research and now understand the crap out of offsets and fit. I was gonna get them rebuilt to fit my car, but ended up striking a deal with OZ America for a set of Superleggera IIIs Link to comment Share on other sites More sharing options...
Drift Motion Posted March 22, 2012 Share Posted March 22, 2012 so according to your logic, wheel manufacture should just make wheels in one offset and supply everyone with spacers instead of investing in expensive molds and making wheels to vehicle specific applications? i see... Link to comment Share on other sites More sharing options...
HoosierDaddy2 Posted March 22, 2012 Share Posted March 22, 2012 No , they would have to make each wheel in two offsets. One version would be at maximum positive offset and the other would be at maximum negative offset. From there , you could get the rim that would work for you and add the spacers to bring the wheel back into its original center line. Also , you would need different widths of each wheel , each with the + & - offset versions. You would also need the different rim sizes , IE 15" , 16" , 17" , etc , in different widths and in the +/- offsets. Otherwise , it sounds like you have a good business model going. Sign me up. I'll need two sets for my Sentra work beater - 16" (summer and winter tires) Two sets for the LGT -18" (summer and winter again) One set for the 69 Bronco fair weather queen. 15" and finally , one set for the 67 trailbeater bronco , this set will need to be in 16.5" AND have double beadlocks on them so I can ditch those nasty Staun internal beadlocks. Thanks , HD2 Link to comment Share on other sites More sharing options...
HoosierDaddy2 Posted March 22, 2012 Share Posted March 22, 2012 Oh snap ! I forgot all about different lug patterns ! Oh well , UNILUGS , HERE WE COME !!! Link to comment Share on other sites More sharing options...
Drift Motion Posted March 22, 2012 Share Posted March 22, 2012 lol...show me how do you add spacer to a negative offset wheel to bring it back to the center line? Why bother making negative offset wheel when you can just add a thick spacer to get the offset from positive to negative? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 22, 2012 Share Posted March 22, 2012 This should clear up positive vs negative offset, front spacing, and back spacing... http://www.roadgrip.net/backspace.gif Link to comment Share on other sites More sharing options...
turbodog Posted March 22, 2012 Share Posted March 22, 2012 I am looking at buying some 06 sti 17in bbs wheels and tires for a good price. I would be putting them on an 05 lgt. I know i could just get the 04 Sti Wheels that are 5x100. But these 06 wheels are a very good deal. I would have to get hub adapters and i don't know if that would work out ok. Curious if anybody has tried this method with positive results??? I know they will probably space out about 25mm over stock. To actually answer your question, you will effectively end up with a 17x8 et28 wheel. http://forums.nasioc.com/forums/showthread.php?t=1504447 While it will fit nothing like stock, it will not be that hard to fit, it will stick out about as far as a 17x8.5" et34 or 17x9" et40, which people fit all the time. In fact, if you were willing to run ~3 degrees negative camber (~4 with lowered suspension), you could probably install front camber bolts and a whiteline rear camber kit, and get them to tuck without rolling fenders. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 22, 2012 Share Posted March 22, 2012 A 25mm spacer with 4 degrees of negative camber? That is a terrible idea. Link to comment Share on other sites More sharing options...
turbodog Posted March 22, 2012 Share Posted March 22, 2012 A 25mm spacer with 4 degrees of negative camber? That is a terrible idea. Oh, don't get me wrong, I think it's a terrible idea too. But I realize that my opinion is just.......an opinion. From a technical standpoint it's certainly possible and actually similar to alot of the "flush" cars floating around here. Link to comment Share on other sites More sharing options...
HoosierDaddy2 Posted March 23, 2012 Share Posted March 23, 2012 lol...show me how do you add spacer to a negative offset wheel to bring it back to the center line? Why bother making negative offset wheel when you can just add a thick spacer to get the offset from positive to negative? LOL , kinda lumped it all together there , didn't I ? It got me to thinking though , if you finish both sides of the rim , you'll get both offsets in one rim .... AND ... wait for it ... you could sell'em to the dually pick-up crowd too , six at a shot! OK , I'm gonna try to stop polluting this thread any further. Link to comment Share on other sites More sharing options...
Drift Motion Posted March 23, 2012 Share Posted March 23, 2012 they already make something like that, 3 piece wheel Link to comment Share on other sites More sharing options...
Jonny bigrig Posted May 9, 2014 Share Posted May 9, 2014 So if I'm looking at 5x114.3 to 5x100 adapters that space your wheels out an inch and the wheels I want measure 16x7 I shouldn't get them I just want a clear answer:spin: Link to comment Share on other sites More sharing options...
mwiener2 Posted May 12, 2014 Share Posted May 12, 2014 Purple. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Jonny bigrig Posted May 13, 2014 Share Posted May 13, 2014 I was more on the lines of teal but I mean purple works Link to comment Share on other sites More sharing options...
