smarty Posted November 12, 2011 Share Posted November 12, 2011 Hey guys, I am looking to install some STI seats into my 05 Legacy and was hoping that some people could chime in with their successful swaps. Looking for people who have actually done it, not just speculating! Let me know what year of sti seats and any snags you had. Thanks for the help, Adam Link to comment Share on other sites More sharing options...
sLiCk WiLlIe Posted November 12, 2011 Share Posted November 12, 2011 I did a swap into my 06 wrx. I used 08 sti seats. Im looking at doing the same swap on my 05 LGT... Ill be switching over my heated seat pads to the sti seats. Im sure the swap is similar... Try this link its what i did on my 06 wrx :http://forums.nasioc.com/forums/showthread.php?t=1971647&highlight=seat+swap Link to comment Share on other sites More sharing options...
DRoc7822 Posted November 12, 2011 Share Posted November 12, 2011 You've saved yourself a lot of hassle having an 05 compared to a 07+. If you have manual sliding seats then thats even better cause the 05 manual seat brackets should fit on 06 STI seats and then that would be direct bolt in. Unplugging the battery while doing the swap and then plugging everything in shouldnt cause any air bag lights on or anything I believe. I have an 07 LGT and ended up selling my 06 STI seats cause of all the difficulties I had. Theres also many other people on the board who have done this. Go to the interior sub forum and theres a guy that swapped over the heat seaters to and lays out everything for you there. Link to comment Share on other sites More sharing options...
smarty Posted November 13, 2011 Author Share Posted November 13, 2011 Thanks for the responses. I think I am going to try the 08's as they have airbags and heat. I will try to post my experience when I get them. Link to comment Share on other sites More sharing options...
nsrt4me Posted November 14, 2011 Share Posted November 14, 2011 I have the 08 Sti seats in my 05 legacy. no way are they plug and play like people say. The seat brackets fit, thats it. You have to fab the seat brackets, use your stock bottom frame, and swap all the sensors and airbags for it to work. Not a simple swap like i thought. Link to comment Share on other sites More sharing options...
smarty Posted November 14, 2011 Author Share Posted November 14, 2011 Thanks that is exactly the info I am looking for. I am going to do new seat covers if I dont do sti seats so I am willing to put in the work. Can you tell me how the airbag swap went? I have never seen the assembly, is it on brackets? Link to comment Share on other sites More sharing options...
Nrw Posted November 14, 2011 Share Posted November 14, 2011 http://legacygt.com/forums/showthread.php/install-heated-sti-seats-into-lgt-reletively-painless-103465.html?t=103465&highlight=STI+seats That should get you going Link to comment Share on other sites More sharing options...
nsrt4me Posted November 14, 2011 Share Posted November 14, 2011 I actually only did the passenger seat so far, Im trying to find time between school and work to knock out the driver's seat. Im going to do a little write up when Im all done to let you know how it all goes. Link to comment Share on other sites More sharing options...
smarty Posted November 15, 2011 Author Share Posted November 15, 2011 Perfect, shoot me some pics when you have time! Link to comment Share on other sites More sharing options...
smarty Posted November 15, 2011 Author Share Posted November 15, 2011 What did the passenger airbag look like? Mounting? Link to comment Share on other sites More sharing options...
nsrt4me Posted November 16, 2011 Share Posted November 16, 2011 The foam fits a little differently, the lgt airbag is smaller than the sti one, but theres two bolts that hold it on, they are exactly the same, its simply swapping them out. Link to comment Share on other sites More sharing options...
DRoc7822 Posted November 16, 2011 Share Posted November 16, 2011 Im not sure about the 08 STI seats (If they the same as the 04/06 STI seats) But I thought that if you swapped over your seat bracket from your OEM seat to the STI seat then they are direct bolt in. Cause its still the same bracket...just fit onto the STI seat. Also the airbag module is riveted to the seat bracket and the passenger weight sensor wont work correctly if you take it off the seat (at least from what I did). Ohh and 1 more thing!! You will have to swap over your seat belt buckles..cause you wont be ever to latch the seat belt unless you swap those over. Otherwise everything should plug right back in...minus the seat heater plug cause the seat doesnt have a seat heater. Unless you swap them over from your OEM seats. Link to comment Share on other sites More sharing options...
smarty Posted November 16, 2011 Author Share Posted November 16, 2011 Thanks for the info. The 08 seats I am looking at have heat and airbags so I should be good..... I think. Soon find out. Link to comment Share on other sites More sharing options...
smarty Posted November 16, 2011 Author Share Posted November 16, 2011 Also does anyone know if the JDM seats have the same bracket as the USDM to mount airbags? None of them come with airbags but I am wondering i they have the bracket to mount too. Link to comment Share on other sites More sharing options...
nsrt4me Posted November 28, 2011 Share Posted November 28, 2011 I finished my swap with 100% functions working. Im having trouble loading pics on. 9.5 hours total for swap. Link to comment Share on other sites More sharing options...
nsrt4me Posted November 28, 2011 Share Posted November 28, 2011 Thats on the 2008 STi seats into my 05 lgt. Link to comment Share on other sites More sharing options...
OGHK87Jay Posted November 30, 2011 Share Posted November 30, 2011 has anyone tried 08 or later on an 08? Link to comment Share on other sites More sharing options...
nwsurfwakeskate Posted March 29, 2012 Share Posted March 29, 2012 how long did it take you to swap everything from the STI seats to your legacy seats. were you starting with power/heated legacy seats or did you have manual legacy seats. I have a 2005 Legacy GT limited right now so I have power/leather/heated seats but my drivers side heater is dead and the leather is starting to crack. wondering if its worth the effort to throw 08+ STI seats in. Is it possible to connect up the heater and airbag in the STI seats? if someone can post wiring mod pics thats exactly what I need. thanks! Link to comment Share on other sites More sharing options...
cjlgt06 Posted March 29, 2012 Share Posted March 29, 2012 Ive got 2011 sti seats iun my 06 lgt limited. Still working on the airbag issue like everyone else. Resistor mod didnt do anything as the passenger seatbelt is integrated into the airbag and seat bladder system. I am wondering if i have to swap out the bottoms to allow everything to mate up?! Link to comment Share on other sites More sharing options...
singincanary Posted November 6, 2013 Share Posted November 6, 2013 Bump from the dead. I'm installing '10 STi seats in my '08 OBXT. They physically bolt right in. I had to swap the passenger side airbag and seat belt receiver over from my car to the STi seats. The airbags are exactly the same size with the same mounting holes but differerent plug underneath. Figured that would be sufficient since everything else clicked right together. Nope. I need to swap the passenger seat sensor over too apparently as although the airbag light doesn't stay lit, the seatbelt beep continues even with the passenger seatbelt buckled. I'm now on the search for pics how to do that. Seriously, what is the need to have different sensors and airbag plugs and seat belts/receivers? Link to comment Share on other sites More sharing options...
branab3 Posted February 9, 2014 Share Posted February 9, 2014 I just swapped 08 STi seats into my 05 LGT. My Legacy seats have many more plugs than the STi seats. I will share what I do. I am venturing into swapping the occupant module over from the Legacy seats to the STi seats and looking for my Legacy Air Bag Control Module to read A-OK and the beeper to cease. Driver's side was a breeze. Mechanically it all bolted directly. Just those darn wires! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Fabius Posted November 1, 2015 Share Posted November 1, 2015 any word on this? Link to comment Share on other sites More sharing options...
