SCHM1AN Posted November 11, 2011 Share Posted November 11, 2011 I got a set of 4 winter wheels and tires from a local guy who owned an OBXT. Stock size on the Legacy is 215/45/17 whereas on the Outback it's a 225/50/17, so that results in a 3" greater diameter on the tire. I put the wheels and tires on last night, and on my way to work they started to rub in the rear. Needless to say I am going to put the 3/8" saggy butt spacers on, but I was wondering if anyone else has successfully run 225/50/17s on their Legacy? Link to comment Share on other sites More sharing options...
krzyss Posted November 11, 2011 Share Posted November 11, 2011 I bet 2010+ Legacies can run this size. Krzys Link to comment Share on other sites More sharing options...
whitetiger Posted November 11, 2011 Share Posted November 11, 2011 if you are running them n stock wheels with the +55 offset, thats whay they rub. outback wheels use a lower offset i believe will aid running that size. Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 11, 2011 Share Posted November 11, 2011 05-09 Outbacks have 225/55/17's on 17x7 +48's. I have Bilstein's on my car, and they fit. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
SCHM1AN Posted November 11, 2011 Author Share Posted November 11, 2011 I got a set of Fittipaldi rims which had the tires mounted on them. I can't find any concrete information about the offset, but I think they're 38mm or 40mm. They definitely stick out a little further than the stock setup. I just ordered a set of 3/8" spacers and the longer bolts from Fastwrx.com which should be here sometime later next week. Until then I might consider swapping my wheels back to avoid any further rubbing. Link to comment Share on other sites More sharing options...
specialB Posted November 13, 2011 Share Posted November 13, 2011 Running 225/45/18's on my summer tires (spec b wheels) and use 225/50/17's on factory WRX wheels and they do rub in the back ever so slightly when I'm loaded up with ski gear and my buddies in the car. http://i3.photobucket.com/albums/y89/Max00racer/tirecomp.jpg Link to comment Share on other sites More sharing options...
