Subframe brace bolts
scoobydoobie
How important is it to have all 10 of those bolts for the subframe brace?
Reason I ask is because during the FSB swap, I removed the subframe brace and the STi front lower arm bar I'd installed on it. When re-installing the brace and arm bar, I over-torqued one of these bolts and managed to strip out the hole where the bolt goes. Just spins.
Is it worth having this drilled and tapped or should I not worry about it?
One of these bolts is missing:
http://img856.imageshack.us/img856/3890/boltso.jpg
That subframe is one of the primary contributors to chassis stiffness, so it's pretty important.
But most of those are bolts that thread into nuts, right? Which one did you strip out, and can you get a nut on the other side of it?
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
He didn't snap the bolt.
I'd probably drill and tap a size bigger, just to be safe.
