maxx189 Posted October 18, 2011 Share Posted October 18, 2011 Hi guys, I did a lot of search on legacygt.com , nasioc.com , montreal-subaru-club.com etc etc And I ended up with MULTIPLES results. I own a 2007 Legacy Spec.B stock suspension stock coil spring STOCK everything. And I wonder what would be the maximum wheels/tires combo size I should buy for my car. I don't wan't my fender to be rolled. I don't want my tire/wheel to hit my fender I am looking at some wheels like 18x8 +35mm with 225 tires is it too much ? is it ok ? thank you very much for your help, Max Link to comment Share on other sites More sharing options...
SubaruTim Posted October 18, 2011 Share Posted October 18, 2011 That low of an offset will stick out past the fender. My old 18x8 +42 were flush with the fender. I'd stick with a 18x8 +44 or highier with 235's Link to comment Share on other sites More sharing options...
whitetiger Posted October 18, 2011 Share Posted October 18, 2011 http://legacygt.com/forums/forumdisplay.php/wheels-tires-43.html look at the first thread in the stickies section at the top. you may need a roll with a +35 wheel. look for a +48 to be safe. Link to comment Share on other sites More sharing options...
mk6933 Posted October 18, 2011 Share Posted October 18, 2011 Since you are stock height, you don't have to roll w/ that offset. I have 17x8 +35 lowered on coils w/ 1 finger gap and it only rub the inner liner. Best if its +40 to +48. Link to comment Share on other sites More sharing options...
maxx189 Posted October 18, 2011 Author Share Posted October 18, 2011 That low of an offset will stick out past the fender. My old 18x8 +42 were flush with the fender. I'd stick with a 18x8 +44 or highier with 235's Wich tire sizes were you using on your 18x8 +42 ? thx, max Link to comment Share on other sites More sharing options...
maxx189 Posted October 18, 2011 Author Share Posted October 18, 2011 Since you are stock height, you don't have to roll w/ that offset. I have 17x8 +35 lowered on coils w/ 1 finger gap and it only rub the inner liner. Best if its +40 to +48. Do you have picutres please ? since a spec.b is kind of lowered oem. Link to comment Share on other sites More sharing options...
mk6933 Posted October 18, 2011 Share Posted October 18, 2011 Need to look for pictures. Actually, stock spec.b suspension is like a monster truck. I believe the fronts are higher than the rears. Link to comment Share on other sites More sharing options...
maxx189 Posted October 18, 2011 Author Share Posted October 18, 2011 Need to look for pictures. Actually, stock spec.b suspension is like a monster truck. I believe the fronts are higher than the rears. Wich tire size were you using with your setup ? thx Link to comment Share on other sites More sharing options...
