moscolokid Posted October 17, 2011 Share Posted October 17, 2011 Hey guys, over the summer i had thrown a P0171 bank 1 out of the blue, i had the car for over a year now and i have a K&N short ram thats been on it since the first week. At first i thought i was running lean from that but then i realized if that's the case, then why didnt it throw the code earlier? Then recently i changed my clutch and put in an aluminum flywheel, after that install the code came on and idling went all shitty. So i changed the front O2 sensor, figured might as well start there. After the change, the car ran fine for about 2 weeks, then the code came back on and i got it scanned and what do you know... im lean again. I checked vac lines and such but still there was nothing. Could the LWFW ultimately throw a code like running lean? or is there actually something wrong here, because i am running out of ideas and if you have any, please feel free to offer. thanks gentlemen. Link to comment Share on other sites More sharing options...
ehsnils Posted October 17, 2011 Share Posted October 17, 2011 Since you are already on the mod bug - remove the injectors and have them checked. And check the manifold gaskets between manifold and cylinder head. Link to comment Share on other sites More sharing options...
Impulse Posted March 29, 2012 Share Posted March 29, 2012 OP: did you ever get this solved? Link to comment Share on other sites More sharing options...
bmx045 Posted March 29, 2012 Share Posted March 29, 2012 you need a tune for that intake. take it off or get a tune. problem solved. Link to comment Share on other sites More sharing options...
