19Legacy97 Posted October 13, 2011 Share Posted October 13, 2011 My back-pressure transducer is like a solid block. no air can go through it EVER. any one know how to take it apart? looks like i could just pull it apart but i dont want to risk snapping something. #2 put on a new right front door today. Door came from a different trim package. ( cloth interior, No accessory light on the bottom) So i switched my door panel on to it. no problem. Except there's no plug in the new door for the accessory light. looks like i could add a the wires for it to the harness from the old door. Main problem here is that the power window/mirror don't work, although the power lock does. all the wiring is there however. Also the doors red on my black suby. She looks like a beater >.< for now... Link to comment Share on other sites More sharing options...
johnegg Posted October 13, 2011 Share Posted October 13, 2011 same year door? double check the connector? if that does not help i guess you could pull the wire harness from the old door and swap it over., but if the wiring difference is in the car that may not help. i don't suppose it would be the window motor, not since you have a mirror problem as well. Link to comment Share on other sites More sharing options...
Stasis Posted October 13, 2011 Share Posted October 13, 2011 I'd just strip the door and leave it till painted. After that you could swap over the wiring from the original door? Link to comment Share on other sites More sharing options...
19Legacy97 Posted October 13, 2011 Author Share Posted October 13, 2011 @ stasis. Good point. Sounds like a plan. Link to comment Share on other sites More sharing options...
