vzwrx Posted October 8, 2011 Share Posted October 8, 2011 I have a 06 LGT with the dual climate controls. For the past 2 mornings when I turn the heat on it only heats the driver side. The passenger side only blows cold air. Both sides are set to 85 degrees. When I restart the car later in the day both sides work normal. I've had the car almost 3 yrs and this is the 1st time it's happened. Any one have the same problem? Link to comment Share on other sites More sharing options...
upshiftn Posted February 13, 2012 Share Posted February 13, 2012 YES.... but it does this after about 30 minutes of driving (only noticed on highway though). goes from normal temp to cold on the passenger side while the drivers side stays normal. annoying but im getting it checked out right now as we speak. think they're ordering a new a/c plate... not sure if that'll fix it but it's covered under warranty so whatev Link to comment Share on other sites More sharing options...
