maniaxzero Posted October 4, 2011 Share Posted October 4, 2011 Thinking about going stage 2. Just want to have an estimate with the cost involved with going stage 2. I know many of you do your own installs but for those that had a shop do the labor, how much was labor for: 1) Downpipe? 2) Up Pipe? 3) Banjo Bolt Replacement? Thinking about going with a E-Tune from infamous, after installation of downpipe, and uppipe, I'm guessing there's an in-between period where I would have to drive the car without a tune, is it dangerous? Could anything be damaged during this transitional period? TIA. Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 4, 2011 Share Posted October 4, 2011 Not necessarily an in-between period where you drive without a tune. You contact your tuner before hand and at least get a base map ready to load immediately after the install. This should be a fairly conservative, and safe map. Log, and go from there. Or if you have an AP, you can load the OTS stage 2 map temporarily while you wait for your base map from your tuner. Link to comment Share on other sites More sharing options...
Sicotic Posted October 4, 2011 Share Posted October 4, 2011 seen the UP for 200-250, DP 300-500. no clue about the banjo lol. And the tune like what he said ^^^^. I'm learning to tune myself so when i run into these situations i can do it myself lol. Link to comment Share on other sites More sharing options...
Heedz Posted October 4, 2011 Share Posted October 4, 2011 You can find an uppipe for 100-120 and about 150-200 for a downpipe. The cnts new are cheap too but then again I'm assuming your roads are salted Link to comment Share on other sites More sharing options...
Sicotic Posted October 4, 2011 Share Posted October 4, 2011 You can find an uppipe for 100-120 and about 150-200 for a downpipe. The cnts new are cheap too but then again I'm assuming your roads are salted where can i find these? Link to comment Share on other sites More sharing options...
RedDawg Posted October 4, 2011 Share Posted October 4, 2011 $85 coated up-pipe http://legacygt.com/forums/showthread.php/fast-motorsports-solid-up-pipes-both-coated-and-uncoated-no-151368.html Link to comment Share on other sites More sharing options...
maniaxzero Posted October 4, 2011 Author Share Posted October 4, 2011 Thanks for the replies but are these part costs or labor costs? I already know the parts cost, more interested in approximate labor for installation on the DP, UP, and Banjo bolt cleaning Link to comment Share on other sites More sharing options...
notthesnail Posted October 4, 2011 Share Posted October 4, 2011 Keep in mind you have to remove the dp to re and re the up, so if you get a labor quote for the up, the dp should basically be free. Link to comment Share on other sites More sharing options...
Sicotic Posted October 4, 2011 Share Posted October 4, 2011 why cant you do it yourself? Not being a smart ass just wondering. Link to comment Share on other sites More sharing options...
maniaxzero Posted October 5, 2011 Author Share Posted October 5, 2011 why cant you do it yourself? Not being a smart ass just wondering. Never done a DP, or UP before. And the fact that I live in the northeast, I know I wouldnt be able to do it in my driveway. When I brought my car to the muffler shop, it was so rusted that he had to torch and cut the bolts to install my catback. Link to comment Share on other sites More sharing options...
Sicotic Posted October 5, 2011 Share Posted October 5, 2011 oh ok gotch, i used to live in ohio had to cut alot of bolts. now i just put some pb blaster on it let sit for a day or to and just use a torque wrench to break the bolts free. Link to comment Share on other sites More sharing options...
maniaxzero Posted October 5, 2011 Author Share Posted October 5, 2011 yup its all that damn salt Link to comment Share on other sites More sharing options...
Sicotic Posted October 5, 2011 Share Posted October 5, 2011 ya but the install is easy i would say no more than 125 for install and thats high for me. Link to comment Share on other sites More sharing options...
Lardo420 Posted October 5, 2011 Share Posted October 5, 2011 if you need to have an in-between period, just stay out of boost and shift under 3k, and you should be ok for a day or so depending on how far u drive it. I had my dp on for about a week and then drove 90 miles to get a tune without any codes. Link to comment Share on other sites More sharing options...
ttnio Posted October 5, 2011 Share Posted October 5, 2011 stay stock ...no worry ...hehehehe... Link to comment Share on other sites More sharing options...
2005pearlwhite Posted October 5, 2011 Share Posted October 5, 2011 i installed my perrin catless up pipe and cnt catless down pipe in about 2 hrs not bad at all i think you should try it Link to comment Share on other sites More sharing options...
notthesnail Posted October 5, 2011 Share Posted October 5, 2011 I'm near Toronto, Canada and had never done exhaust work before, either. The worst part of the job was the donut gasket end of the DP because I had to scrape it off. The bolts were fine after 4 winters and 75k miles. If you search the forums and make sure you have all your required parts and tools handy, it's not a bad driveway job. I'd consider wrapping the DP before you install it. DEI Titanium is probably the easiest. Link to comment Share on other sites More sharing options...
