Glossary of trip meter codes (er --)?
emilbus
What's it saying? AFAIK, your "trip meter" doesn't display error codes during normal operation.
Any sort of problem relating to the running of the car has to have its code pulled through the OBD2 port using a reader/laptop.
It can be used to read out codes if you really want it to. It can show some error messages such as:
ER SS - ABS speed sensor error
ER HC - High speed CAN bus error (this comes up when reading / writing the ECU ROM)
There are probably others. Which did you see? My favorite is the ILL.5 error. ;)
