joeblow Posted September 12, 2011 Share Posted September 12, 2011 I did a search and came up with its something with the electrical system. I recently had my 2008 5EAT up on stands for 3 weeks to replace the turbo. When I finally had everything put back together, the battery was dead. When I jumped it, I came up with a flashing on the dash and the car displaying "Run Mode Change System Check." I went to Autozone and they tested the electrical system and it all checked out; battery, alternator, starter, etc. The car will always turn over, but it takes holding the key over for a few seconds longer than normal. I also have an oil leak to track down and fix, but I don't think its related. I haven't had a chance to get the car tuned for everything I did, so maybe one of the new mods is the culprit. The current tune is for a standard stage 2 with upgraded TMIC Here's what I've got, the items with "new" next to them have never been tuned for, since they were just installed. BNR TD05H-18g (New) RacerX FMIC (New) Walbro 255 (New) Invidia Catless DP Stock Injectors (will be maxing these out when I tune it to keep myself from going nuts and shattering my 5EAT until ClimberD can mod the 08 valve body) It's cool; I'm with the band Link to comment Share on other sites More sharing options...
joeblow Posted September 13, 2011 Author Share Posted September 13, 2011 Anybody? It's cool; I'm with the band Link to comment Share on other sites More sharing options...
bmx045 Posted September 13, 2011 Share Posted September 13, 2011 from searching the forum I found that it was caused by a bad battery. http://legacygt.com/forums/showthread.php/run-mode-change-system-check-82184.html Link to comment Share on other sites More sharing options...
joeblow Posted September 13, 2011 Author Share Posted September 13, 2011 I too found that thread, but my battery checked out just fine when I stopped in at autozone. Someone else's turned out to be a fried ECU. So it could be any number of things, I didn't know if anybody could look at my mod list and know right off if something I just added would cause my issue. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
shadowsports Posted September 13, 2011 Share Posted September 13, 2011 The "Run Mode Change System Check" is an error coming from the S-I Drive, but everything still points to the battery. Have the battery itself load tested. Link to comment Share on other sites More sharing options...
