xero287 Posted September 13, 2011 Share Posted September 13, 2011 No high-flow intake...Everything is stock for intake, has the silencer as well. So i guess I should be alarmed about this? lol sigh, I love car problems. Link to comment Share on other sites More sharing options...
Mill Posted September 13, 2011 Author Share Posted September 13, 2011 hehe i know .. yea when on cruse it can be a lil annoying .. where is your airfilter ? engine bay or down in the bumper area ? Its in the engine bay.... the underhood temps are retardedly hot compared to my jeep (I suppose the turbo might have something to do with that.) Its like a hot air intake... maybe extending it into the bumper area would shut it up, but then I'd be too lazy to get in there and clean it. Mine makes this noise too, stock intake with filter. At 75%+ throttle it wooshes. I figure with the increased flow from the downpipe the turbo is sucking in more air anyway. Stock wouldnt be a big deal to me since I dont usually cruise at 75%+ throttle. That and the tires I have are hella loud, but appear to be wearing just fine. Link to comment Share on other sites More sharing options...
bmx045 Posted September 13, 2011 Share Posted September 13, 2011 for what it's worth- modifying the stock intake screws with the maf readings. been there, done that, logged that. I removed the silencer box underneath the airbox and it made my maf readings all wacky doodle. For the best performance, leave the intake duct on, and keep the silencer in. Removing the intake duct does not help performance one bit. I logged pre/post duct removal on an 89 degree day. Highest intake temps were 124, lowest was 111. With the duct on the highest was 110 and lowest 94. Significant improvement, and the silencer messed with my fuel trims a little when I removed it. Recommendation: keep the entire intake system stock until you get an intake setup, don't hybrid the airbox....it's shape and design is like that for a good reason. It may not produce a bump in your pants but it will be better for performance and mpg overall rather than modding the stock box. Link to comment Share on other sites More sharing options...
xero287 Posted September 13, 2011 Share Posted September 13, 2011 So...the whooshing sound is normal with the stock intake then bmx? Link to comment Share on other sites More sharing options...
bmx045 Posted September 13, 2011 Share Posted September 13, 2011 it's healthy and safe as long as the entire intake system is intact, yes. However you'll want to look elsewhere to see if there's any boost leaks or vaccum lines pulled off, air/boost escaping from places, even between hose clamps can make weird noises. The throttle body coupler, if it's loose, can cause a whistle or a farting sound when you get on boost. any idle issues? Link to comment Share on other sites More sharing options...
xero287 Posted September 13, 2011 Share Posted September 13, 2011 the only idle issue is that when started cold it idles at 1.5k, but a quick tap on the throttle diminishes that. Link to comment Share on other sites More sharing options...
bmx045 Posted September 13, 2011 Share Posted September 13, 2011 that's normal. I meant roughness Link to comment Share on other sites More sharing options...
xero287 Posted September 13, 2011 Share Posted September 13, 2011 Oh, nope. not at all. ALTHOUGH I think I have an exhaust leak somewhere that 4 people can't even find. I redid the gaskets on all of the manifold and uppipe, so its pretty upsetting. I only know I have an exhaust leak because my car is louder than stock even though I have the stock exhaust minus the up/dp. Link to comment Share on other sites More sharing options...
frank_ster Posted September 13, 2011 Share Posted September 13, 2011 block the mufflers with rags and such .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
legaZ Posted September 13, 2011 Share Posted September 13, 2011 this is normal for an open filter on a turbo car enjoy it. it's awesome. Link to comment Share on other sites More sharing options...
xero287 Posted September 14, 2011 Share Posted September 14, 2011 block the mufflers with rags and such .. uhhhhhh Link to comment Share on other sites More sharing options...
